![]() | Home > Technical > Stranded, help please. |
chris38 Member Since: 24 Oct 2014 Location: Lancaster Posts: 34 ![]() ![]() |
It was pretty wet on the way up here, snow and slush so pretty moist. Cheers
Chris 300tdi Defender 90 |
scotsstag Member Since: 17 Jun 2012 Location: D+G Posts: 539 ![]() ![]() ![]() |
If you're really struggling then luckily there is a great independent L.R specialist just a few miles down the A75 from you at Twynholm.
They are called W.B.GALLOWAY and their number is 01557-860240, ask to speak to Bill, he runs the place. ![]() Edit... Forgot to mention they have a recovery truck as well just in case you needed recovered to the workshop. 04' 90 Td5 CSW.. |
Thanks for that will give him a ring this morning Cheers
Update,
After getting it trailered back home got a friendly auto leccy to have a look. Much melted insulation stripping later and full dash removal traced the short back to behind the heater box, two wires had shorted together and caused major damage to the loom further up. It's now back up and running and I have the satisfaction of knowing that it's not going to burst into flames any time soon. Looking at the damage of the wires that were replaced looks like that could have been a possibility. Thanks for your ideas and offers of help. Cheers Chris 300tdi Defender 90 |
Good to hear, have you got photos of the burnt loom insitue ? Was there any indication what caused them to chaff, protruding bolt for example. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
No photos just bits all over the floor.
Leccy didnt see anything that had caused it to break down. Just wear and tear I guess. Cheers Chris 300tdi Defender 90 |
