Home > Maintenance & Modifications > Dinitrol & Dynamat
JOW240725
Dinitrol & Dynamat
Hi, I'm looking for to carry out (by others) a full rust treatment and sound proofing. If the dynamat covers the inside of door skins does this mean you can't dinitrol the door? Or can you dinitrol then add dynamat on top, will it stick?
Thank you.
James
Post #474642 20th Nov 2015 5:48pm
Only the inner door frames are Dinitrolled which are steel.
No problems with Dynamat as the two are kept separate.
Post #474655 20th Nov 2015 6:27pm
