![]() | Home > Maintenance & Modifications > LT77 Gearbox Question |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288 ![]() ![]() ![]() |
Could be a number of things. 1st thing i'd check would be the reverse light switch (if it is sticking/notchy). Remove and test selection.
FLFAMILY Member Since: 23 Mar 2014 Location: West Midlands, Sunny FL Posts: 45 ![]() ![]() ![]() |
Thanks for your response. I have the gearbox tunnel out right now. Where is the reverse light switch connected? I will test this now and hopefully get this sorted.
Found the switch. Giving it a shot now by removing and testing the selection.
boxer Member Since: 12 Jun 2011 Location: north yorkshire Posts: 48 ![]() ![]() ![]() |
Hi had the same problem, first remove the rubber gear gaiter or lift it up, you will then see the top of the alloy gear selector housing check for wear mine had badly worn not expensive to replace , then remove the deriten ball and spring housing two bolts located on the side of the gear selector it has shims so don't loose them. strip the spring housing clean the ball and spring apply grease when reassembling then refit.could also be worth removing the alloy gear selector top, again not a hard job clean and grease up. Hope this helps.
