![]() | Home > Td5 > Turbo booster box and limp mode? |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 ![]() ![]() ![]() |
Not sure if this is a right concept...
Once the ECU sense the turbo over boots, ECU will cut fuel and lead the TD5 to loss power... If the Turbo booster box install will hack the ECU there is "no over boost", so the TD5 would run normal!!! My TD5 going uphill with loss of power, on flat its really OK, MAF filter change, injector harness change, clean red plug, Fuel filter change, engine oil change...Turbo waste gate rod push...etc. Still the same happened when going up deep hill(gas pedal become soft), so I'm thinking using this Turbo Booster box to hack the ECU, to put the TD5 in normal, is it possible?? ![]() |
Thats the problem, I don't have Nanocom, and dont know anybody does...There is not much TD5 here in my country...
By the law all TD5 need to be destroy in year 2019! So I can only guess so far ![]() |
