Home > Maintenance & Modifications > Rear Step Bumper
Browjam
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Havana
Rear Step Bumper
Hi there,
I was wondering if anyone has fitted a rear step bumper. If so, can it be a one man job and are any specialist tools required?
Best regards,
james
Post #422795 12th May 2015 7:10am
I have one and it was fitted by the main dealer. However, I had to take it off within a year to sort out the fading paint on the rear crossmember.
It's an easy job, only difficulty will be if any of the items don't quite line up correctly due to LR build tolerances.
No special tools. The instructions on how to fit are in Topix if you care to look through them and see if it's something you would be happy to do yourself.
Post #422820 12th May 2015 9:39am
Browjam
Supacat,
Thank you for your guidance - I will have a look on Topix.
All the best
James
Post #422821 12th May 2015 9:41am
GUM97
I've fitted quite a few. Very simple to fit, some bits are a bit fiddly but noting too bad. It's not too heavy to lift either, so easily a one man job Thumbs Up An engine to TDi for!
Post #422971 12th May 2015 6:21pm
Browjam
Gum97
Many thanks.
That is what I wanted to know as I can't see the Mrs wanting to help😀
James
Post #423004 12th May 2015 8:04pm
