Home > Maintenance & Modifications > any link between no filler cap and engine warning light?...
Page 2 of 2 <12
X4SKP
Just thought I would add to my Engine Warning Light issue recently
or MIL (Malfunction Indicator Lamp)... Idea
Installed the ScanGaugeII...simple enough, Set up also simple, so far from me... Thumbs Up
Checked for Logged Error Codes DTC (Diagnostic Trouble Code) and got...
So the same as Venomator recently.
There is online information on this and it has been covered on Def2Net
K9F was right, mine reset itself after a few driving cycles (about 6).
http://www.defender2.net/forum/post69774.html
I will keep an eye on this, now possible with the ScanGauge, will also check fuel consumption
which appears to suffer if the MAF (Mass Air Flow) Sensor is failing... so far no re-occurrence.
Thanks again for the help from the Forum... Thumbs Up SKIP
Post #403422 1st Mar 2015 5:00pm
Page 2 of 2 <12
