Home > Technical > Rear Crossmember Torx bolts
Grenadier
There are four Torx/Star bolts on my crossmember, a pair either side. I am fitting bumperettes but do not have the right sized tool. Before I head down to my friendly garage and ask them to whip them off for me, any idea what they're for? Will I need to take the bumperettes down and pop them on immediately or can I come home once the bolts are off and not expect anything to fall off? Advice appreciated, ta. Thumbs Up
They can be seen on the photo....
 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #391427 22nd Jan 2015 12:16pm
landy andy
They hold body onto the chassis.
Andy
Post #391430 22nd Jan 2015 12:19pm
leeds
As Andy says hold body to chassis.
Most rear bumperettes do not require those bolts to be undone.
Most swingaway wheel carriers would do however.
Whilst fitting the bumperettes you might as well give the rear crossmember a good clean/waxoyl etc at the same time.
Brendan
Post #391437 22nd Jan 2015 12:30pm
JWL
And there was me thinking that they were part of the seat belt fixings for the rear load space seats Whistle
Post #391449 22nd Jan 2015 12:51pm
steve E
Wales
Apparently they are JWL on the seven seater SW.
Post #391453 22nd Jan 2015 12:55pm
Grenadier
Brendan
Hi Brendan, thanks. Just to confirm that you are referring to the four Torx bolts on the crossmember, not the pairs on the White bodywork. Not wholly clear on my first photo, this photo may be better. It's the two bolts, very bottom left of the crossmember, just above the exhaust.
Post #391454 22nd Jan 2015 1:01pm
munch90
there for the brace for rear seat belt/tub mounting
Post #391456 22nd Jan 2015 1:05pm
leeds
Ooops fun and games of the internet/phone conversations, understanding exactly what people mean
Those two on the crossmembers are for seat belt brace bar to rear cross member. On our white 90 they have been replaced with hexagonal headed stainless bolts.
It might be worth your while getting a set of torx bit drivers which fit into a 6mm/1/4" socket. Probably less then 10 euros for a set.
Would still suggest you clean/paint/waxoyl rear member whilst you are doing it. Thumbs Up
Brendan
Post #391462 22nd Jan 2015 1:28pm
munch90
really you want proper socket torx set as doubt you will undo them with a 1/4 bit driver , they a m10 thread so in normal hex head bolt would be 17mm , bit too much for 1/4 drive tools
Post #391464 22nd Jan 2015 1:40pm
Grenadier
Brendan
Thanks again Brendan. The bumperettes come with SS hex head bolts. Will follow advice on cleaning and touching up my crossmember.... Whistle Monsieur Le Grenadier
Post #391471 22nd Jan 2015 2:06pm
If you undo both of those bolts remember that there is a double spacer that is placed in from the side.
Post #391517 22nd Jan 2015 5:58pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
If you do take them off you will probably find they are a complete and utter pain in the backside to undo (They certainly were on our 05 plate model). give them a good soaking with some kind of penetrating fluid before attempting- I will be replacing the ones on ours when the weather improves!
Chris
Post #391533 22nd Jan 2015 6:53pm
Grenadier
Thank you all for your help. Thumbs Up Monsieur Le Grenadier
Post #391680 23rd Jan 2015 8:09am
Djcla
What do these 4 bolts do again the 2 at each end of the cross member in the picture (above the exhaust)? Ive noticed my friend doesn't have them on his and I need new ones as they are knackered. Anyone know the part numbers?
Post #774072 20th May 2019 6:23pm
They hold the end of the seatbelt mount on models with rear seats. If you don't have rear seats, you won't have these bolts or setscrews.
Post #774079 20th May 2019 6:34pm
