Home > Puma (Tdci) > Puma 2.4 cold starting issue.
AMV
Scotland 2009 Defender 90 Puma 2.4 CSW Zermatt Silver
Morning all, I am looking for some guidance/advice in identifying a frustrating issue with my 2009 Puma 2.4 defender. The problem is a starting issue which has the following symptoms.
1. From cold, engine starts, runs for between 5-30 seconds and then either
a. Cuts out like ignition key has been turned off
or
b. Runs very rough for up to a minute and then cuts out
2. Trying to re-start immediately results in engine cranking as normal, but will not start
3. Turning ignition off and waiting for circa 20 secs (seems until a relay under seat clicks) then trying a re-start results in car starting as normal.
4. Points 1-3 repeat for 5-6 times then car starts and stops as normal all day
I have it booked into local Landrover dealer at start of January but wondered if there was some obvious sensor or something I could do whilst I was off work over the holiday period. My friend plugged in his DTC tool, but no fault codes were found (was a pretty basic one to be fair)
thanks in advance for your help
Post #382962 29th Dec 2014 11:19am
dgardel
Italy
outside temperature?
Diesel Parafin? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #382972 29th Dec 2014 12:03pm
Lorryman100
Check the relay under the drivers seat for corrosion and that all the pins are making contact. Check the loom around the relay holder for any signs of damage, water ingress or corrosion. Next thing would be a Ohms test on a glow plug with a DMM to check for an open circuit on any of the glow plugs and also check the glow plug rail for amps when the ignition is switched on and the glow plug cycle starts.
From the symptoms you describe and that you can hear a relay click then it starts as normal then this is the first place I would look. It sounds as though the glow plugs are not receiving any power during the pre heat stage which causes the engine to start and then die
From another post to save me rewriting it:
Lorryman100 wrote:
During the preheat stage, the ECM receives the engine temperature from the cylinder head temperature (CHT) sensor and this is what determines the preheat time. The lower the temperature, the longer the preheat time. There is a maximum preheat time of about 8 seconds at -20°C or lower.
Once the engine has started, the glow plugs enter an after-glow phase. The after-glow phase only operates at engine speeds below 2500 rpm, above that the after-glow phase is stopped to increase the longevity of the glow plugs. There is a maximum after-glow time of about 30 seconds at -20°C or lower. If the CHT is above 50 degrees C there is no after glow.
If the connection is loose then yes that can be a cause of the glow plugs not working. A easy test is to use a DMM and do a voltage / amps check on the rail. The glow plugs draw a decent amperage so a loose connection will stop the maximum current from being delivered to the plug rail.
HTH :thumbsup:
Post #382978 29th Dec 2014 12:15pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
I had a similar fault on mine.
It turnerd out to be the immobiliser.
Might be worth a look.
Good luck.
Post #382983 29th Dec 2014 12:23pm
Lorryman100
I agree. The immobiliser is the next part of the fault finding process if the glow plug system checks out OK. Thumbs Up
Post #382984 29th Dec 2014 12:27pm
AMV
thanks all for the immediate responses - really appreciated. I will follow up on the glow plugs and relay and check continuity/current in the first instance. The car is garaged overnight so temp not too extreme. Had a look under the drivers seat. The area looks brand new with no signs of ingress or corrosion, but will give relay and cct. a thorough check. Again, thanks for the steer. rgds.
Post #383002 29th Dec 2014 12:55pm
Cupboard
My 2011 Puma seems to have the glow plug light lit for a lot longer than that (though it might just seem like an age) and it does it even if it's been up to temperature and only sat for a couple of minutes. Is that right?
My old Honda wouldn't bother with glow plugs in the summer or if the engine was still warm and our TD5 doesn't seem to if the engine is warm.
Post #383071 29th Dec 2014 4:49pm
