![]() | Home > Maintenance & Modifications > Eberspächer D2 in cubbybox |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I have an Eberspacher D2 here that I am going to fit this week under the cubbybox mounted in a Nakatanenga undercubby heater box. I also have on order from Nakatanenga a fitting that goes on the tank filler pipe to allow the fuel to be drawn from the tank without the need to drop it or to drill a hole into.
Under cubby heater box ![]() Click image to enlarge Fuel tank filler pipe fitting ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Stue5 Member Since: 06 Jul 2014 Location: Marche Posts: 111 ![]() ![]() ![]() |
I like the look of the boxy thing
![]() silly question how did you get the nakatanega web site to speak English? I Have only seen it in German ![]() ![]() The fuel pickup is still on my defender as the D2 was fitted behind the drivers seat as it was a three seater 110 environment agency's van. Range Rover p38 4.6 99 lpg(gone ![]() ![]() |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
Hi .. If you use Chrome on the iPad it will do the translation for you. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Ellisboy Member Since: 13 Oct 2013 Location: Deep South Posts: 539 ![]() ![]() |
I would tap into the fuel line and not bother with a Seperate tank. Ebbers don't use great amounts of fuel.
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 587 ![]() ![]() ![]() |
Hi Stue5, Possibly from when I did mine, the pictures are on expedition portal. It has worked out really well putting it into the cubby, takes up a little room but still plenty for other stuff in there such as sat nav, cameras etc. it doesn't get hot either. I plan to make a false bottom to stop it getting cluttered down the sides of it. Since the pictures the only other update is a side exit exhaust for it with twin silencers, extremely quiet now. You may need to join the expedition portal to see the pictures. http://www.expeditionportal.com/forum/thre...r)-fitment ![]() |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1639 ![]() ![]() |
Having done a few of these mainly into defenders,you cannot tap into td5 fuel lines reliably
The easiest way is to use the spare blanked off pipe on top of the td5 fuel pump. It's very important to use right size fuel pipe and there is a max length the heater will draw the fuel from..if memory serves me a foot up or down and 3-4 in length. Seen a few under the cubby box in 90s,in battery box,under rear seats in 110, a few under the bonnet which works ok but not ideal as they don't like water ,mud and dust. Mine is behind seats in a 90 plumbed into main tank. Fuel use wise depends on model and temp and how long it runs.before I pumbed mine in i used a boat tank of 10 ltrs which would do a full day or night . |
