![]() | Home > In Car Electronics > Dodgy Pioneer Satnav |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Try a laser cleaning disc. This sounds like typical failure of the laser though unfortunately. Some disc heads can be dismantled and the laser power turning up, this is usually only a problem when using copied discs, assuming your map disc is a proper one?
Steve 02' 110 TD5 Double Cab Rebuild Thread |
defender4 Member Since: 22 Jun 2011 Location: South East London Posts: 411 ![]() ![]() ![]() |
Thanks for the advice Steve. I didn't know there was such a thing as a laser cleaning disc. That sounds worth a try.
Er, no. The disc is a copied one. The originals had ancient maps and replacing with Pioneer original discs was just way too costly. So it's my own fault (in part)! Rob |
If you still have an original disc, even if it is out of date give it a go to see if it works.
The discs are I believe 'lens cleaning' discs. You used to be able to get them from Tesco etc. Havent used one for a while but I believe they have little brushes on the back to 'dust' the laser head. Steve 02' 110 TD5 Double Cab Rebuild Thread |
