![]() | Home > Maintenance & Modifications > Guidance with Bulkhead removal bar installation |
FLFAMILY Member Since: 23 Mar 2014 Location: West Midlands, Sunny FL Posts: 45 ![]() ![]() ![]() |
Pictures are in my gallery, not sure how to embed them in the message
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
/\ /\ If you open the iMage in your Gallery you will see an option, underneath it, to add to your posting list, this will place a thumbnail under your text input box and if you click/tap on this it will insert it to your post...
![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
Thank you
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
You can use nut and bolt instead of using the plates
![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Many thanks Chris and thank you for all your help with all the parts.
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 ![]() ![]() |
A question on this rather than starting a new thread.
How easy is it to remove the bulkhead? What advantages/disadvantages does it have? |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 578 ![]() ![]() ![]() |
I have removed mine,myself.
Not too difficult,if you are OK with a grinder. You need to strip out the seats & carpets,cover all remaining glass,to protect it from sparks.Take the rear side panels off,(2 people needed to lift them off.) You dont need to remove the roof,I just jacked it up from the rear. Then just cut out the bulkhead,and grind back,paint the raw edge,et voila. ![]() ![]() Click image to enlarge |
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 ![]() ![]() ![]() |
I've done this on mine too, pretty easy for anyone who's handy with a grinder, you'll have to be handy with a hoover for the mess at the end too! Click the link in my signature, there's a paragraph or two in there from when I did it. Tom
@tditomprice 100ā€¯ Defender Hybrid 2010 Alaska White 90 HT |
Hhhhhmmmm, might leave that mod and get the bulkhead re-painted instead.
