Home > Off Topic > Disco 2 v8 1999
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Disco 2 v8 1999
I am sorry if i should not post this on here but my brother is thinking of buying a disco 2 v8.
Has anybody had one of these?
Anything he should be looking out for?
I had a read and they seem problems with the heads?
Anything else?
Thank you
Fabio
Post #354598 30th Aug 2014 4:18pm
keith
Brakes .
Post #354600 30th Aug 2014 4:32pm
K9F
I had a 1998 'R' registered 3.9 V8. Bulletproff engine based on a late 1950s Buick. I LPG'd it (single point) and it was very affordable to drive. NOT good in floods or extreme wet as the distributor can get wet. The bodywork/brake pipes and especially the fuel pipes are worth going over. The fuel pipes are rigid and bolted onto the chassis and when they rot out it can be a bodyshell raise job to replace. I cut the old ones out and used later neoprene TD5 ones cable tied to the chassis to get round this but costly nevertheless. Get a good one and it will be a dream to drive (I miss the VCool, get a lemon and they can be a money pit. Get it inspected first.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #354603 30th Aug 2014 4:57pm
Happyoldgit
I had one some years ago, nice motor but they are getting on a bit now. Check alpine windows for leaks and rear floor for rot ....in fact check the whole of the bodyshell for rust [lift mats and check footwells, check inner wings, cills etc]. Steve.
http://forums.lr4x4.com
Post #354615 30th Aug 2014 6:15pm
Rot weakness on D2 isn't the body (that was the original Disco) - it's the rear chassis. They rot like nobody's business from in front of the back axle to crossmember and can be very expensive.
Post #354624 30th Aug 2014 7:16pm
Fabio
Thanks for the comments Gents.
It is 4.0 v8
The car is in Portugal, the rust is not a big problem.
It is more the rest...
I look at my defender and compare it with a 15 year old one in Portugal and there isn't much difference...
I take it the biggest problem is the engine?
It has 150k...
Anything else?
It is he's 1st land rover and i don't want him to get in trouble with he's wife"the boss"... Very Happy
Thank you
Fabio
Post #354640 30th Aug 2014 8:30pm
