![]() | Home > Off Topic > Disco 2 v8 1999 |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2236 ![]() ![]() |
Brakes .
I had a 1998 'R' registered 3.9 V8. Bulletproff engine based on a late 1950s Buick. I LPG'd it (single point) and it was very affordable to drive. NOT good in floods or extreme wet as the distributor can get wet. The bodywork/brake pipes and especially the fuel pipes are worth going over. The fuel pipes are rigid and bolted onto the chassis and when they rot out it can be a bodyshell raise job to replace. I cut the old ones out and used later neoprene TD5 ones cable tied to the chassis to get round this but costly nevertheless. Get a good one and it will be a dream to drive (I miss the V
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
I had one some years ago, nice motor but they are getting on a bit now. Check alpine windows for leaks and rear floor for rot ....in fact check the whole of the bodyshell for rust [lift mats and check footwells, check inner wings, cills etc]. Steve.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
Rot weakness on D2 isn't the body (that was the original Disco) - it's the rear chassis. They rot like nobody's business from in front of the back axle to crossmember and can be very expensive.
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 ![]() ![]() ![]() |
Thanks for the comments Gents.
It is 4.0 v8 The car is in Portugal, the rust is not a big problem. It is more the rest... I look at my defender and compare it with a 15 year old one in Portugal and there isn't much difference... I take it the biggest problem is the engine? It has 150k... Anything else? It is he's 1st land rover and i don't want him to get in trouble with he's wife"the boss"... ![]() Thank you Fabio |
