Home > Technical > Need to replace turbo where to purchase ?
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
Have been inspecting an prepping car for forthcoming overland trip to pyrenees.
Noticed significant play in turbo spindle and figure wise to replace before trip,
Was thinking of recon unit ? But who would you purchase from?
How much setting up is required re boost pressure after fitting?
Many thanks in advance Thumbs Up
Post #318540 23rd Mar 2014 9:30pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I,m sure some of the site sponsers can supply you with a new/recon unit, but failing that you could try Midland Turbo,s we use them at work and they will send a courier to pick up your unit check it out for you and phone before undertaking any repair work.They usually repair and despatch in a couple of days.
Check out their website for contact details. 2005 Td5 90 XS
Steve
Post #318544 23rd Mar 2014 9:37pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Bas site sponsor he does standard units and vnt for the td5 he will look after you and uses the company that rebuilds all of JLR turbos Thumbs Up 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #318545 23rd Mar 2014 9:37pm
amondeggs
Thanks both for the info Thumbs Up
Lou I might give them a call tomorrow to get an idea of price Thumbs Up
Post #318555 23rd Mar 2014 10:10pm
mk1collector
Aet turbos in Wakefield
Post #318572 23rd Mar 2014 10:35pm
Skeggy 90
England 2011 Defender 130 Puma 2.4 SW Bali Blue
The waste gate actuator will be set by the manufacturer you will not need to adjust it. I would recommend replacing the engine oil and filter at the same time. a number of turbo companies insist on this for warranty reasons.
Post #318580 23rd Mar 2014 11:08pm
bell-auto-services
Hi
We have both VGT hybrid turbos and standard recon turbos in stock. Not adjustments are needed after fitting as all is done on the turbo flow bench when made. Please do remember you can't reliably check for baring wear by "lift" on the shaft when its not under oil pressure. The baring only works as a baring when its pressurised with oil that does remove and amount of shaft lift compared to when not pressurised.
Std here. http://bellautoservices.co.uk/store/td5-de...bmenuid=57
Regards Pete.
Post #318581 23rd Mar 2014 11:13pm
amondeggs
Thanks all again for input Thumbs Up
Pete thanks for sharing your knowledge re play in the turbine bearing, every day is a school day Very Happy
With what you have said in mind is there anyway of testing my turbo to ensure that is it all ok?
Any help is very much appreciated Thumbs Up
Post #318738 24th Mar 2014 5:37pm
bell-auto-services
Hi
I cant give a real scientific answerwithout stripping it fully, however generally if the barings are really warn as you turn the compressor wheelbyhand to check lift is the comp wheel toughes the comp housing it has problems.
Also the comp wheel blade tips should be sharp and not eaten away from debrit in the air or melted from overspeeding or hard work.
Pete
Post #318776 24th Mar 2014 7:18pm
amondeggs
Ok thanks again Thumbs Up
Will have a close look,
If I find issues will be on the phone for recon unit Thumbs Up
Really appreciate your advice Thumbs Up
Post #318864 24th Mar 2014 11:01pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Have you tried paddock they sell genuine garret ones Wink Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #318884 25th Mar 2014 1:20am
theorangebandit
It is easy to mistake free play as failure. What is the fualt/symptoms?
Post #318886 25th Mar 2014 3:54am
amondeggs
To be honest there are no symptoms,
I have just been looking over the car to try to ensure that nothing lets me down on my trip to the pyrenees. I looked at the turbo as the car has covered over 200,000 miles. I found a bit of play in the spindle and assumed that it should not be there. Thanks to Pete I now realise that this does not mean I have a problem Very Happy
I'm going to have a closer loo at the weekend to see if the play is enough to cause any catching.
It's probably me just being over cautious Rolling Eyes
Thanks again to all who have offered advice Thumbs Up
Post #319045 25th Mar 2014 7:01pm
cornish rattler
Mine has a little free play and the finns are slightly worn aswell so will be replacing mine soon Smile Graham
Post #321715 5th Apr 2014 12:17pm
