Home > Technical > Rear End "Clonk" |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
See how much play there is on the diff pinion - grab the prop and see what moves!
Could also be any of the other rear bushes - trailing arms for example. |
10th Mar 2014 5:25pm |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 283 |
My bet is play on diff pinion splines. Take off and put back on with loctite was the technical repair!
If not rear drive flanges worn! |
10th Mar 2014 5:32pm |
Marky Boy Member Since: 25 Oct 2013 Location: Maidenhead Posts: 96 |
Thanks very much. I have just checked the Haynes manual and it shows the rear drive flange and half shaft as one piece, can you confirm this is complete tosh ?
Apologies for the newbie question..... |
10th Mar 2014 8:23pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 556 |
Earlier ones where one piece but the later ones have separate drive flange.
Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
10th Mar 2014 8:54pm |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
I have a clonk that is rather helpful as when I get a clonk I know that I forgot to grease the prop. Id say start at the props first as its a damn sight easier to attend to and potentially the cause
11th Mar 2014 8:05am |
Thankfully Saturday looks nice, I think I'll be I under the Defender then. Thanks for the replies, glad the Haynes manual is right
11th Mar 2014 8:11pm |
