Home > Puma (Tdci) > 2.2 oil level going up, fuel economy going down...
Rick81
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Galway Green
Hi All!
My four month old 110 2.2's fuel consumption has gone down from a steady 26mpg to 23mpg over the last three tank fills, nothing has changed in my driving style or journeys.... At the same time the oil level which has always remained constant at halfway up the hatched area on the dip stick has increased to the top of the hatched area. The vehicle mileage is just under 6,500miles and up til now the oil level has not moved since delivery. Has any one else experienced these symptoms? I am waiting for the local agent to call me back with suggestions!
Post #314203 7th Mar 2014 9:57am
munch90
diesel in oil from dpf regen ?
Post #314206 7th Mar 2014 10:01am
Rick81
If so it seems like a lot... Is it normal? Can't be doing it any good surely? Would it do this at such a low mileage? I only use esso or BP fuel in it so it ought to be reasonably clean anyway
Post #314207 7th Mar 2014 10:04am
munch90
I don't think anyone really really knows if its ok to have diesel in the oil .. seems a lot of cars do it if its start stop short trips .
we had a lot of Vauxhall vans in for engines because of it , but that was blamed on not stopping when oil too high light came on so level kept rising
years ago if someone said " here is a litre of diesel now go and put that in with your oil " you would have told them to @@@@ off
but it seems ok to do it now!!!!
people will say just change the oil , but that's no joke with the price of oil for dpf equipped car
autodata state low ash oil must be used in dpf equipped defender
Post #314211 7th Mar 2014 10:18am
Naks
it's definitely NOT ok to have diesel in the oil Shocked
high probability this is an injector leaking/loose, fuel dilution can do some bearing damage if not taken care of right away.
worst case scenario your engine will go bang
have it fixed asap! --
Post #314217 7th Mar 2014 10:40am
munch90
autodata state on some cars to leave oil on lower mark to allow for diesel going into oil!
that's why some cars have oil level sensors now because of this
Post #314220 7th Mar 2014 10:46am
milesr3
2016 Defender 90 Puma 2.2 XS CSW Keswick Green
According to the MY12 workshop manual, active DPF regeneration typically occurs every 250 miles, takes up to 20 minutes and will increase fuel consumption by 100%. Unless you are getting the amber DPF warning light, it seems unlikely that DPF regeneration is going to increase your oil level so dramatically.
The Defender is the first DPF equipped car that I've owned that I have not been able to feel when it is doing a DPF regeneration; apart from the odd whiff of hot exhaust and noticing the fuel level drop a notch on a long run. 250 miles is very frequent and maybe this means they can keep it short and sweet.
Is there a high pressure fuel pump somewhere on the block? These are problematic on BMW engines, where a failed seal will fill the sump with diesel.
Post #314228 7th Mar 2014 11:25am
Rick81
Thank you all for the comments, I don't do many short runs in it, most are 30-50 mile minimums in each direction with 150-300 mile run every few weeks. I'm not sure if it has a high pressure fuel pump on the block anywhere. My old TD5 had a problem with the injector seals that caused the sump to fill up with diesel and that got the garage I was using fairly excited so I assumed this is not an ideal situation...
Post #314234 7th Mar 2014 11:43am
Paul-Kent
Now I'm getting concerned!
My commute is 6 miles each way. Are these short trips likely to cause damage?
Post #314350 7th Mar 2014 7:06pm
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Just take it for a thrash every now and then .
Post #314367 7th Mar 2014 8:08pm
Not damage but more frequent active regeneration with it's consequent side effects of increased fuel consumption and oil dilution.
Post #314426 8th Mar 2014 6:47am
