Home > Puma (Tdci) > DPF removal - the facts |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
Received thanks Pete. Just having a read now.
6th Feb 2014 8:50pm |
RockJaw Member Since: 15 Oct 2013 Location: United States Posts: 317 |
WoW!
So if you own one of these on a Game Ranch in Botswana or Kenya or Namibia, where there are no roads for miles what then? What if you have these on Curtis Island, Queensland, Australia, deployed as a recovery vehicle where there are no roads, only 800 metres of rocky beach and a massive big gaping hole in the ground where gas extraction occurs? Or if you are using these in one of the many mine shafts hundreds of metres underground as a utility vehicle in the mining process, what do you do then? Or if you are in a mining operation along the Amazons or in the Rio Grande du Sul where you are surrounded by dense tropical rainforests for hundreds of miles? What then? Or in Papua New Guinea where these Defenders are among the very few vehicles capable of negotiating through rough tracks in the very misty and very dense very high altitude hardwood forests - what then? Or at a lighthouse on the Southern tip of New Zealand where there is 12 months of of ice, sleet and snow and top speeds of only 10-15 Mph for about 2 minutes? Huh? Now what do you do? Tricky? You bet! ****CENSORED**** |
7th Feb 2014 12:58am |
psimpson7 Member Since: 20 Nov 2013 Location: Gold Coast, Qld. Posts: 221 |
As far as I am aware no 2.2 sold Australia has the DPF anyway. (upto 2013MY anyway)
I am waiting to see if our new one has one being a 2014 MY |
7th Feb 2014 1:54am |
[quote="psimpson7"]
Ye mate, unfortunately LR Aus decided to take the models straight from UK in exactly the same configuration as UK - seems it worked out cheaper for them. Previously they took the South African specs, so ye, the Aussie Defenders are identical to the UK models since around 2010 I think. Even seatbelts, windshields, tyres are now all the same spec so they drive them straight off the boat directly to the customer complete with all the rubbish Belgian components attached to them like a filthy smell. Luckily Aussies could give a toss for EU rules so there will be loads of old cobbers with all the gear to fix these things. So far as I know the electronic mapping needs to be done by the South Africans or one of the Brits until one of the Aussies cracks the chip on the latest 2.2, other than that the Aussies just get on with quietly sorting the mess out without making a huge fuss about it all. Your new 2014 2.2 will have a lovely DPF performance anchor and a CAT furnace blaster under the driver's cabin plus an airconditioner which only works at 70 mph with all the windows open - exactly what you need for equatorial Australia! The old Air conditioner systems which used to the same as the good South African units are also a thing of the past. In the extremely unlikely event that you happen to have a cold spell on the equator, at least the vehicle will heat up okay! ****CENSORED**** Last edited by RockJaw on 7th Feb 2014 9:51am. Edited 1 time in total |
7th Feb 2014 6:55am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8088 |
we run 2.2s with DPFs there are weeks, maybe months on end when they do not get above 15mph, but they are run for in 3hr blocks so do get to temp. no regen issues on 2.2s to date. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
7th Feb 2014 7:15am |
@ jst
Nice!!!! I was actually under the impression that Land Rover offered to stuff and frame 2.2 owners who don't experience regen problems, clearly my info is inaccurate! How frequently have you done oil changes? and have you found any diesel in the oil? ****CENSORED**** |
7th Feb 2014 9:49am |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3786 |
When do you expect delivery, (we waited 6 months!) & what specs/options do you have? Cheers, pickles. |
7th Feb 2014 10:54am |
30th March apparently. I am expecting an update on that tomorrow from the dealer. We signed the order on Nov 22nd.
In terms of spec; 90 SW (in std Aus spec, so air-con, Alpine stereo/sub etc etc) - Loire blue - Dual finish wheels and MTR's That's it! although I already have one pile of accessories here from Duckworth parts to fit when it arrives! |
7th Feb 2014 1:05pm |
Has Australia not moved to Euro5 somewhere in 2013? Thought that I read that somewhere, and that at some point in the last three months of 2013, new Puma 2.2 would start to be delivered with a DPF. Or do I have that wrong? Surely your dealer must be able to tell.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
7th Feb 2014 1:10pm |
we only keep them 6mths. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
7th Feb 2014 9:18pm |
Ours was built in Sep '13, & has the "R" in the vin which apparently means it's not Euro V, so no DPF. My Dealer says it doesn't have one. There was another post here recently talking about what the Defender "Quick Start" manual says about the DPF,.....there is no such mention in my manual, which also has a different p/n to the one quoted for the UK manual.
Cheers, Pickles. |
7th Feb 2014 9:21pm |
If yours does not have the DPF and it is delivered AFTER June 2013, well then you are one lucky guy.
We were advised by LRA during June 2013 that all 2.2 delivered as of that date would include the DPF - which is why we cancelled all outstanding orders. ****CENSORED**** |
8th Feb 2014 1:24am |
Well mate, I reckon LRA gave you the wrong info. ULR (Dealer) tell me they've never seen a DPF on a Defender.
Cheers, Pickles. |
8th Feb 2014 3:31am |
patclan Member Since: 13 May 2010 Location: Gold Coast Posts: 20 |
[quote="RockJaw"]
My 2.4 air con works great even crossing the Simpson Desert in 45deg heat and doing 25kph, works much better without the cat though that is just like have a furnace in the front with you, and no MOT in QLD so all good. |
8th Feb 2014 6:18am |
