Home > Maintenance & Modifications > Map reading light
Blacktt600
England 2008 Defender 110 Puma 2.4 XS CSW Cairns Blue
Map reading light
Anybody fitted a map reading light and if so which one. Looking at fitting 2 on the trims above the rear passenger doors for the kids to read when away on holiday.
Post #304583 2nd Feb 2014 10:41pm
Terryt
I have a hella map light .easy to fit ,robust ...we use them on the response vehicles at work and they take a hammering and last well.
Terry
Post #304607 3rd Feb 2014 1:18am
Happyoldgit
Long arm Hella mounted on the side of the cubby box, fused +ve direct from battery. Would be easy to mount on the rear of box for rear seat use too [taking it as read that it's a CSW USW without bulkhead]. Steve.
http://forums.lr4x4.com
Post #304636 3rd Feb 2014 8:57am
I fitted a RRC auto dipping mirror, it has 2 map lights built in Thumbs Up
the same as this one on ebay
Post #304638 3rd Feb 2014 9:10am
dgardel
Italy
I have the Outback roof console with map LED spot lights Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #304659 3rd Feb 2014 10:56am
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Maybe a bit pricey being an LED one but I use one of these...
http://www.carbuildersolutions.com/uk/hard-wired-map-light
Used one last year to do the BAMA Salisbury Plain night navigation competition and it did the job nicely, being able to use it in red mode as well as white meant that I could read the map with it and still be able to see outside when I needed to and I suspect it also meant less reflected glare for the driver. The switch is perhaps a little fiddly but OK when you get used to it.
Fitted the same one to Pam's 90 after the Salisbury plain event.
Being an LED the current draw is tiny so no problem if it gets left on. http://www.yorkshireoffroadclub.net/
Post #304665 3rd Feb 2014 11:15am
Porny
Site Sponsor
The OSRAM units are nice...
http://www.mobilecentre.co.uk/index.php?ma...eyword=map
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #304675 3rd Feb 2014 11:58am
g-mack
good idea!! My 109 thread
my youtube channel
Post #304752 3rd Feb 2014 5:28pm
Pickles
That looks like a nice item. Couldn't find it on Ebay.
So, you fitted this in a Defender?...If you did, how did you do it, does it use the same fittings as the Defender? I like "Factory/OE" type options, & this one looks good to me.
Cheers, Pickles.
Post #304864 3rd Feb 2014 9:54pm
pretty easy to fit,, un-snap the defender mirror, 3 screws, the mirror is simply screwed on Thumbs Up
electrical feeds taken from interior light.
Post #304967 4th Feb 2014 9:50am
mk1collector
Any pics of it fitted please?
Post #304996 4th Feb 2014 11:21am
