Home > Maintenance & Modifications > 110 splash guards fitting ?
df1
Anyone fitted the Entreq splash guards ?
I have these a while now and have tried a few times but can't figure out exactly how to fit, maybe if someone had a fitted photo.
Post #293114 25th Dec 2013 2:58pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
photo's fitted in this thread here
http://www.defender2.net/forum/topic11875.html
Post #293121 25th Dec 2013 4:43pm
Morepower
New Zealand
I've fitted these to mine.... You need to drill the body and fit the alloy rivet nuts the add a bead of silicone between the body and guard... I had Brendan Powder coat mine (Black) and you can barely see them fitted... If you need some photo's I'll nip out when it stops raining and take a couple..
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #293177 26th Dec 2013 8:42am
df1
Thanks for both replies.
Is it a td5 you have them fitted to ?
Post #293215 26th Dec 2013 1:52pm
Romadog
Pics of mine fitted as I thought they should be and sprayed in the black stuff !! Would be goodfor mine if the RH was wider, but I assume it allows for fuel filter on Td5 etc. However from inspection most of the mud spray marks the plate more to the outside anyway. Thumbs Up
Post #293260 26th Dec 2013 6:04pm
df1
Thanks for all the help, them photos are exactly what I was looking for.
The smaller guard had me well confused, makes sense now, job for tomorrow.
Thanks again for the help, had me head wrecked.
Post #293282 26th Dec 2013 7:30pm
Romadog
I had the same problem. I didn't want to fit them incorrectly, especially after paying for them !!
Post #293287 26th Dec 2013 7:43pm
df1
Am I correct in saying that's a 90 they are fitted to ?
Took a few photos this morning of mine (TD5 110).
L/H/S outrigger
R/H/S
It seems I can only fit them "upside down".
Still confused, have I the wrong guards ?
They don't sit flush on the outrigger either.
I fear I've spent a wad of cash on these and they are not for my vehicle.
Post #293374 27th Dec 2013 10:03am
df1
Just had another look at the photos, are these for a S/W only ???
Post #293375 27th Dec 2013 10:07am
DF1 - I have these fitted to a 2010 110 SW, I don't remember having any issues fitting (drop me a PM with your email address and I will send you some pics)
From memory the plates are "sided", when fitted the logos are the correct way up
Post #293380 27th Dec 2013 10:47am
Michaels Defender
United Kingdom 2013 Defender 110 V8 Petrol XS CSW Auto Orkney Grey
I have the same problem, I bought a set of these from 4x4 Overlander and each guard is a different length, but my MY2013 110 SW, the guards need to be the same longer length to fit correctly, if not I would have a 100mm gap at one side for no reason, I have contacted 4x4 Overlander on quite a few occasions, but has been unable to resolve the issue. Its a good useful product if they had supplied a correct fitting set., I can show photos if anyone is interested. JE Zulu 110 now sold
Carpathian 110 also sold
Defender 110 camper now in build
Post #293476 27th Dec 2013 6:51pm
Romadog
The pics of mine above are on a 110 USW. If you have a 110 3 door, then you won't have the body crossmember that these brackets are designed to protect.
Post #293507 27th Dec 2013 9:10pm
leeds
Unfortunately I do not have a set of photos of these guards fitted. Since we are a few thousand miles from home am unable to fit a set and take photos at the same time..
The logo should be the correct way up, they are handed and fit at the front of the rear wheel arch.
I will try contacting Olaf and see if he has a set of photos available.
Brendan
Post #293544 28th Dec 2013 12:32am
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Looks to me that the plates you have are not the right shape to be fitted there or not for that particular chassis
I'm not an expert and don't spend much time underneath but are these for the front or rear ?
They def don't look like the other ones in the pics
Good luck Thumbs Up It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #293550 28th Dec 2013 7:12am
I have sent df1 some photos of them fitted to my truck, to be honest it's difficult to get wrong, so I would assume there have been some subtle changes to the underside between td5 and tdci. which is true due to the different middle row seats on the tdci vs the td5.
wheel arch before fitting
Post #293561 28th Dec 2013 8:15am
