Home > Puma (Tdci) > My 2.4 CSW XS purchase has worn track rod ends and a missing
johnnyd
Hi All
Just took my recent purchase in for a waxoyl, and i got a call from the garage to say the vehicle has very worn track rod ends (needs replacement) and a missing steering damper, I purchased it from someone on the forum who said it had never been off road. Are the above points indicative of anything, or normal on a 5 year old vehicle of 29,500 Miles ?
JD 2008 TDCi 2.4 XS CSW
Post #283715 20th Nov 2013 12:48pm
Glynparry25
No steering damper Shocked Surely the shteering wheel was dancing around the place on uneven surfaces?
Track rod ends- mine lasted 40,000 miles but a lot of that was rough tracks- but at the same time, if it hasn't got a steering damper it would put a lot more vibrations/ stresses on them which would result in excess wear.
Glyn Dog Sheep
Post #283717 20th Nov 2013 12:57pm
Caterham
missing damper...
seems strange - its not like they're hard to get hold of or cost the earth or difficult to fit?
Post #283720 20th Nov 2013 1:03pm
Above is what I thought, how can you leave it missing. Confused ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #283722 20th Nov 2013 1:07pm
johnnyd
Can/do they just fall off ? Could it have been removed for a reason ?
Post #283728 20th Nov 2013 2:01pm
Caterham
they're bolted on so I doubt (anything is possible of course but I've never heard of it).
can't imagine why it wouldn't be replaced unless it was simply faulty / leaking and someone opted not to replace it?
I've also not heard of them being nicked in the middle of the night.....but once again anything is possible.
Post #283730 20th Nov 2013 2:14pm
westfield106
2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Re: My 2.4 CSW XS purchase has worn track rod ends and a mis
johnnyd wrote:
Hi All
JD
john
i can say that whilst i owned the vehicle it had not been offroaded !!!
the steering damper was removed due to siezure and not replaced at the wifes request as she found it easier to drive without it !!! it was her daily driver not mine.
as for the worn track rod ends these were not noted on the last mot or service as requiring attention and havent caused me reason to check for wear ????
if you have any further queries then please feel free to call me on my mobile no.
john
Post #283756 20th Nov 2013 3:37pm
johnnyd
Hi John
OK many thanks for the update, that explains it I think, The garage were totally bemused and slightly worried as to the wear on the track rods and the lack of the damper, but i guess the lack of the damper would explain the worn track rods as some people have said here.
Best Regards
Post #283780 20th Nov 2013 5:07pm
jst
i run a 90 without a steering damper, its not the end of the world as the OP has obviously noticed by not realising it wasn't there.
TREs do wear, treat them as a service item, they are cheap and easy to change. on my trayback they go on avg one every other day of use. on mainly road going vehicles you will get alot more out of them (90k on my last td5) Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #283942 21st Nov 2013 9:28am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
The steering damper on my 90 MY11 unbolted itself and fell off, and if it wasn't for the fact that I heard it hit the steering guard, I probably wouldn't have known, certainly from on road driving, there was no difference in steering feel at all.
Mine only unbolted itself at one end, but I suppose it's possible that yours may have detatched itself completely.
Pete
Post #283946 21st Nov 2013 9:54am
SteveG
2005 Defender 90 Td5 CSW Belize Green
Personally, I wouldn't worry about a Defender being used off-road. A bit poor show on previous owner selling it without refitting a new steering damper though, but may have genuinely forgot about it.
Has it had brake fluid, coolant, diff oils, gearbox oils changed? I suspect not given mileage. However, if I bought this, that's what I would change along with doing an engine oil change, air filter change and finally topping up hubs and propshafts with correct grease.
That way you know you are starting ownership from a good reference point and you can then keep up good maintenance from now on. That along with regular use, should mean you have relatively trouble free use from your 90
Have fun with your new purchase.
Post #283948 21st Nov 2013 10:02am
familymad
My steering damper on our 2.4 departed the vehicle on the M40 northbound. Had never been offroad!
LR fitted a new one under warranty. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #284026 21st Nov 2013 3:31pm
jst
it would seem these are something to check then! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #284047 21st Nov 2013 4:15pm
johnnyd
Yeh John has contacted me to say it was just something he had forgotten about so all is good, new one fitted today with new TRE's also, and a waxoyl........Smells now ;(
JD
Post #284094 21st Nov 2013 7:17pm
