Home > Maintenance & Modifications > Puma - mounting of additional (carling?) switches
Jim_Bean
Guys - what would be the best way to mount a few additional switched for roof lights, rear work lights, auxiliary power etc?
I've looked at a few consoles - mud and nakatenaga.
Is there another way of easily mounting Carling switches? I thought there was a pod for the side of the dash trim for the TD5, does this not exist for the Puma?
I really don't want to cut into the dash if possible, rather use and additional mount/pod/console
Recommendations?
Post #282114 14th Nov 2013 1:07pm
Mud do a cubby box swith / drink holder thingy Thumbs Up
Post #282115 14th Nov 2013 1:12pm
FCX do a great cubby box
Post #282117 14th Nov 2013 1:13pm
Jim_Bean
FCX is a bit much for me - the Mud 3 switch and cup holder thingy looks good!
Post #282119 14th Nov 2013 1:15pm
Cheshire110
Can recommend the mud puma pod.
If you're clever you can not cut the dash top, but I did.
I cut in the coin tray bit and made sure the hole was the exact size of mud's USB socket, so if I remove the puma pod then I can leave a USB socket fitted in the place of the hole. Cheers, David
Post #282124 14th Nov 2013 1:38pm
Jim_Bean
Thanks David. Do you have a photo at all for inspiration?
I'm also looking at the mud roof console as an option.
Post #282128 14th Nov 2013 2:04pm
Tim_NZ
Australia
I did a DIY cubby box.... http://www.aulro.com/afvb/projects-tutoria...panel.html
Cheers,
Tim
Post #282129 14th Nov 2013 2:40pm
Cheshire110
^ this is what I did, I found it handy that I could get a couple of switches and also have room for a 12v and USB. As I said if I ever remove the pod, I will use the 12v/USB to plug the hole.
You have to drill 4 screw holes to mount but you can get away with 2 or maybe even silicone etc - the thing isn't heavy at all!
But tbh the kit comes with 4 plastic rivets which I will use to block the holes if I remove it, and they seem pretty tidy. Cheers, David
Post #282133 14th Nov 2013 2:53pm
Jim_Bean
That looks great, hmm much much cheaper than the Nakatenga option.
Is the front face metal or plastic? What is the overall quality like?
Post #282296 14th Nov 2013 10:07pm
Cheshire110
its fairly good, plastic all over.
pretty thin (not quite flimsy, but somewhere approaching) and the plastic is similar to the plastic used in the defender (scratchy and plastic) but it doesn't matter.
tbh its good its thin as it allows you to cut whatever holes etc you like in it easily, wouldn't want it much thicker. its perfectly sturdy enough to hold whatever you fit.
does the job well and looks almost factory fit, i like it Smile Cheers, David
Post #282299 14th Nov 2013 10:16pm
