Home > Puma (Tdci) > Loss of throttle response!
Toplink
57 plate 90 80k. Traveling on A38 from Plymouth to Exeter 65-70 mph at the bottom of an incline,I depressed the throttle pedal to maintain speed coming off over run.No response nothing slowed down to 50mph just able to maintain that speed,but foot flat to floor.Pulled over checked all the connections etc all satisfactory.Turned off waited 5mins,started engine carried on with journey as if nothing had happened. Checked out ecu codes,no codes. Any ideas? Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2014 Triumph Tiger800xc
1999 Discovery 2 td5
1982 Ransomes TSR300D.
2002 Yamaha XT600e.
2010 Freelander2 (the wifes)
2008 John Deere X140
Post #281123 10th Nov 2013 9:48pm
No MIL light / limp mode? Sounds like a possible fuel starvation issue. (Wouldn't worry) what revs were you at? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #281124 10th Nov 2013 9:51pm
vinsell
Italy 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Re: Loss of throttle response!
I had the same and at the end I replace egr valve, turbo actutor harness (that was broken) and turbocharger (because actuator was gone). Now my Def is better than new. Note that egr valve and turbocharger are different than the original and harness was been modified according to a technical bullettin. They are improving defender with our money! Confused
Vinicio https://google.com/+VinicioSelleri
Post #281163 11th Nov 2013 6:32am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
@Toplink
Would be interested to hear if you get to the bottom of this - I had a similar problem with a VW Passat recently, switched off then on and all fine - ran fine for next two thousand miles. It's just started again, wondered if it was weather related.
Post #281224 11th Nov 2013 1:01pm
Lorryman100
Unplug the accelerator pedal multiplug and coat with electrical contact cleaner. The area around the plug can get wet causing mineral contamination of the plug pins. Also when you are there check the condition of the harness.
Post #281301 11th Nov 2013 6:22pm
Toplink
Right update.
No mil on and no codes on SDD or Snapon micro scanner.
Historic fault noted on SDD @456 miles that was on the second day from new.
Ran through an air passage flow test on EGR and Turbo,nothing conclusive.
LR tech bulliten recommends replacing actuator arm(only costs a few quid so worth a try).
As problem has only happened once,I think I will just drive it on and see what happens.
Thanks for your replies. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2002 Yamaha XT600e.
Post #281760 12th Nov 2013 10:33pm
JoostKenya
Kenya
Is the raddiator low on water?
And was the engine almost overheating?
In that case the ECU is taking the power down and no fault being logged in the ECU.
In other cases (like the throttle) I would expect a fault in the ECU. Joost
Tornado TD5 Racer
Defender 110 V8
Defender 136'' 300Tdi Safaricar
SIIA V8 Hybrid
Post #281784 13th Nov 2013 7:30am
Toplink
No over heating probs and no coolant losses and no fault codes logged.
Its done it another 4 times on a recent 1.4k trip to Scotland. Only way to correct is to pull over and switch off ingnition turn straight back on and away you go. I can now do this on the move it saves pulling over. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2002 Yamaha XT600e.
Post #289672 11th Dec 2013 10:39pm
Volume Control Valve on fuel pump malfunctioning or sticking perhaps. Very similar to some of the symptoms I had, and generally won't raise a DTC.
Post #289741 12th Dec 2013 10:30am
