Home > Puma (Tdci) > I need help: Puma goes in Limp mode |
vinsell Member Since: 06 Feb 2009 Location: Brindisi (Italy) Posts: 74 |
[quote="Lorryman100"]
Ok, full dtc was P2562-34, but they wanted to replace turbocharger. After a discussion I told them to repair harness and to replace MAP sensor. Finger crossed. Thank You Vinicio p.s. I'll keep You all updated. https://google.com/+VinicioSelleri |
14th Oct 2013 3:50pm |
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
14th Oct 2013 4:03pm |
Yes Daniele but You could have an earth fault on the circuit with an earth fault on the wire. Isn't it?
Vinicio https://google.com/+VinicioSelleri |
14th Oct 2013 4:11pm |
[quote="vinsell"]
Ok, not so well... Wires to turbo's actuator were broken and have been repaired as required by related technical bullettin. MAP sensor replaced. So now I have MIL turn off and no DTC but the TURBOCHARGER is not working and Dealer is going to replace it (with a reconditioned one)! I'll have to pay more than 1500 euro. I'm really depressed. Vinicio https://google.com/+VinicioSelleri |
17th Oct 2013 1:17pm |
Hi Lorryman100,
they are replacing turbocharger ( including actuator) because it is impossible for an official LR dealer to replace actuator only. I hope they tested modified actuator's harness and made all necessary software update, but ( really) I'm not sure. The cost of 1500 euro include harness repair, new MAP sensor, regenerated turbocharger with actuator, all necessary gasket and bolts and manhours (they ask 45 euro/hour). Do You think they are joking me? (Maybe) Do You think I have to inform LR Italia? Consider that I'm little bit tired and I need the car asap. You can be sure that it's my last LR and I've been driving LR since a got the license: Series III, 90, Discovery 300tdi and then this f...... Deforder! Vinicio https://google.com/+VinicioSelleri |
17th Oct 2013 6:36pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Ahh with everything being done 1500 euros is about right. The turbo and modulator are one unit and if one fails the whole turbo unit needs replacing, what I was asking was if the turbo had failed or were the dealers saying it was the modulator that was causing the fault. If it is the modulator that was suspected then after getting the modulator harness fixed that would warrant me to thoroughly check the repair first before even thinking of changing the Turbo. If it was an issue with the Turbo itself ie bearings vanes etc then that would be a separate issue to the modulator harness repair and would warrant a complete new unit. Might be worth considering fitting the Nakatanenga annealed copper gasket as well as the Turbo will be removed?
HTH Brian. |
17th Oct 2013 8:01pm |
Modulator is the problem thay said. They said they checked harness repair too but I'm not sure because they wanted to change turbo since the first time I explained the problem. I already got Nakatanenga gasket fitted but I can't fit it again because of the warranty on this turbo's replacement.
I don't know, I'm really tired of all these car's issues. I treated my Def with all the attentions but since the begin I got a lot of problems, and I have still to complete the payment Thank You and All You Guys for all Your tips. Vinicio https://google.com/+VinicioSelleri |
17th Oct 2013 9:04pm |
lost gringo Member Since: 28 May 2018 Location: santiago Posts: 18 |
i realize this post is dated 2013 but here in 18 the list goes on.
may i suggest that these problems of unsatisfactory performance and service are due to a lack of understanding of the beast? the land rover is a complicated monster made even more rowdy by bosch and the can buss tech. but i have never seen a spec on can buss. why is that? i think the techs at lr havent seen one either so how could they begin to understand it? i am currently fighting the same issues others have had since 2005 or so, probably for the same reasons but there still isnt a good database to go to for fixes. (got to say the best database seems to be lorryman) would it be possible to consolidate historical problems and solutions in one single post? ie. symptom, details of symptom:temp, etc, dtc`s, things tried, solution. whatever helps to get the job done. just my two pesos.... |
16th Jul 2018 4:29pm |
