Home > Puma (Tdci) > replacing clutch
yanto
Wales
replacing clutch
Hi all
Can anyone tell me if there's a way you can see if a clutch has been changed? my dealer told me they changed the clutch last month and the same symptoms have returned and new symptoms have also started. I dont think it was changed? This was a warenty fix on a 2010 90.
Thanks guys.
Ian
Post #269670 26th Sep 2013 9:05pm
smb
Hi Ian,
Sorry I can't help, but What are your symptoms?
Regards
Steve
Post #269680 26th Sep 2013 10:32pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Only way to tell is to drop the gearbox or whip out the engine .. both well beyond the capabilities of the average owner Confused
You could check bell housing bolts to see if they show signs/marks from being removed ... won't confirm clutch has actually been replaced, but at least you'll know the box/engine have been split Thumbs Up
HTH Guns and Landrovers .... anything else is irrelevant.
Post #269772 27th Sep 2013 2:28pm
