![]() | Home > Puma (Tdci) > heater system |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Probably only Puma related but when I turn the heat on, i only have a hot stream of air out of the left dome. The openings in the middle and the right dome stay cool.
Not sure if it's normal, but I was actually planning on mounting the iPhone in front of the left dome as i never use that one. Can't be good for my phone during winter time, I guess? ![]() Anyways, is it normal you only get heat out of one of the four openings? |
Not normal, but others have suffered similar quirks...
http://www.defender2.net/forum/topic5335.html?highlight=heater http://www.defender2.net/forum/topic4932.html?highlight=heater http://www.defender2.net/forum/topic1048.html?highlight=heater http://www.defender2.net/forum/topic1924.html?highlight=heater If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
I'm starting to believe I'm useless with the search function. Thanks!
Car is almost in need of its first service, so hopefully they can fix it while the car's in. |
