Home > Puma (Tdci) > heater system
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
heater system
Probably only Puma related but when I turn the heat on, i only have a hot stream of air out of the left dome. The openings in the middle and the right dome stay cool.
Not sure if it's normal, but I was actually planning on mounting the iPhone in front of the left dome as i never use that one. Can't be good for my phone during winter time, I guess? Whistle
Anyways, is it normal you only get heat out of one of the four openings?
Post #269531 26th Sep 2013 9:31am
K9F
Not normal, but others have suffered similar quirks...
http://www.defender2.net/forum/topic5335.html?highlight=heater
http://www.defender2.net/forum/topic4932.html?highlight=heater
http://www.defender2.net/forum/topic1048.html?highlight=heater
http://www.defender2.net/forum/topic1924.html?highlight=heater If you go through life with your head in the sand....all people will see is an ar5e!!
Post #269536 26th Sep 2013 9:52am
tookaphotoof
I'm starting to believe I'm useless with the search function. Thanks!
Car is almost in need of its first service, so hopefully they can fix it while the car's in.
Post #269549 26th Sep 2013 10:46am
