Home > Puma (Tdci) > Snorkels for 2.4 Pumas |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
I'm sure that snorkels aren't engine specific. If that add says 2.2 then it will fit to the 2.4 too so long as you confirm that it's the correct side for your fender in take
29th Jul 2013 6:14am |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 |
I had a metal mushroom top on a 2.4 puma and worked fine. Can't remember the make I think it was a mantec.
29th Jul 2013 6:20am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17380 |
I think that my metal mushroom top RAI is Bearmach. It works fine.
29th Jul 2013 8:28am |
ive been leaning toward the mantec mushroom myself cheap and functional
29th Jul 2013 8:53am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
don't forget a RAI is not a Snorkel as they aren't watertight 2.4 90 XS
29th Jul 2013 9:09am |
speedymarktd6 Member Since: 02 May 2011 Location: Worcestershire Posts: 102 |
I've got a mantec metal snorkel for sale all complete and i had it on my puma and worked fine
Pm me if your interested |
29th Jul 2013 9:13am |
shaun6 Member Since: 06 Mar 2013 Location: Houghton Regis, beds Posts: 46 |
Try this one, I have bought one and they are in perfect condition and it fits a puma
[url]http://www.ebay.co.uk/itm/130719785605?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 Regards Shaun [/url] |
29th Jul 2013 10:28am |
gprich Member Since: 14 Jun 2013 Location: East Devon Posts: 42 |
Hi Shaun,
Any chance you could post a pic of it fitted on your truck? Gareth. |
29th Jul 2013 12:32pm |
This is what it would look like, I have not fitted it yet as I need to get up the courage to drill through the A pillar to fit it.
http://defender110.webs.com/apps/photos/photo?photoid=107534997 Regards Shaun |
29th Jul 2013 12:48pm |
"Get a Grip!" Engineering solution! Why drill the A-pillar at all? Bond the bracket with Sikaflex 291i instead!!!! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
29th Jul 2013 12:54pm |
Anybody actually done this? Photos? |
29th Jul 2013 2:03pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
^^^^ That's assuming the paint will stick to the metal enough to support the snorkel
29th Jul 2013 2:11pm |
The instructions for Safari also state drill out the mounting holes to 16mm does that mean you automatically drill out to that size? No! With careful alignment you can get away with 12mm only......
Engineering solutions are invariably always met with sceptisysm..... Sikaflex 291i sticks to just about anything that is non-greasy. You just need the patience to allow it to cure first. Most of the support is provided by the larger mounting bolts lower down not the A-frame ones. Fine, should it not work for you what have you lost? Then you'll just have to crack on and drill the holes as instructed. Another 'Engineering Solution' is of course that the inferior coating on the pillar bracket rots out in about four-five years. So if possible get a stainless bracket made from the onset....then again it'll probably be the wrong material/gauge colour for some perhaps? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
29th Jul 2013 2:18pm |
OK calm down dear... I was merely speculating/joking on the naff paint finish of LR's and that the paint will probably fall off with the snorkel attched to it
29th Jul 2013 3:01pm |
