Home > Puma (Tdci) > EGR Stuck shut
Dieselhead
EGR Stuck shut
Thats what my nanocom tells me whats wrong with my mates puma.
The engine light came on so I had a look for him.
Is it best to just replace the EGR unit or can anything else be done??
Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #204436 22nd Jan 2013 7:28pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
If you have a Bas or alive tuning box they can turn off the egr 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #204456 22nd Jan 2013 7:57pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Switching off is just stuck shut without a warning isn't it Wink
Post #204463 22nd Jan 2013 8:25pm
Clear the code for now and see how it goes. If it comes back on / keeps coming on all the time then it needs replacing. It may also put out some MAF readings incorrectly too as it can alter it a bit. $W33T $0U7H3RN $UG4R
Post #204465 22nd Jan 2013 8:32pm
Dieselhead
Thanks,
Did clear the code. 2nd time I have done this now
Hes got a dynachip remap which gives him 450m per tank what ever hes doing. Something must be working right as I cant this kind of mpg with mine
If it kicks up again I will have to renew the EGR for him as hes no good with the spanners Laughing Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #204470 22nd Jan 2013 8:43pm
With the EGR closed it probably will add a bit of MPG.
And changing one been there done that. As normal a proper pain in the a** to get at! $W33T $0U7H3RN $UG4R
Post #204473 22nd Jan 2013 8:45pm
Lorryman100
Simple test to see if the EGR is responding....can you hear the self clean cycle on shut down? Sounds a bit like 5 x chukka chukkas? Also the nanocom is a very good tool but unfortunately does not differentiate between tested and untested dtc's which can lead to serviceable parts being replaced needlessly. Thumbs Up
Some random readings from my Puma taken with the nanocom, yet no tested dtc's found when using the MSV2 or IDS straight afterwards!
NANOCOM - PUMAENG.APP - PUMA ENGINE fault file
0404 - 73
Exhaust gas recirculation (EGR) control circuit
range/performance
actuator stuck closed
0404 - 72
range/performance
actuator stuck open
0299 - 00
Turbocharger A under boost condition
0100 - 29
Mass or volume air flow A circuit
signal invalid
1935 - 14
Brake switch sensor signal
circuit short to ground or open
02A8 - 00
Cylinder 4 balance - (injector 3) restricted
029C - 00
Cylinder 1 balance - (injector 1) restricted
02A4 - 00
Cylinder 3 balance - (injector 2) restricted
0404 - 73
range/performance
0299 - 00
0606 - 49
Engine control module (ECM) processor
internal
electronic failure
0100 - 64
signal plausibility failure
1169 - 00
Fuel rail pressure sensor in range but high
068A - 00
Engine control module (ECM) power
relay deenergized - too early
I'm sure that you will agree that some of the above dtc's are a little worrying? Yet the dealer level tools I have never logged the same dtc's as the nanocom. Confused
JMTW Thumbs Up
Post #204476 22nd Jan 2013 8:48pm
