Home > My Defender > The FCX Defender 130 build thread
Page 10 of 25 <123 ... 91011 ... 232425>
mk1collector
Was the foam you put on after the dynamat adhesive on the back? Also is it closed cell and where did you get it? Sorry for all the questions but I'm nearly ready for that stage.
Ray
Post #203809 21st Jan 2013 10:29am
Hi Ray,
The foam was bought from Acefoam:
1 off 2000mm x 2000mm x 40mm Eggbox Style Acoustic Foam with Self Adhesive backing £53.50 each
All Quotes include VAT and Parcelforce delivery ( orders placed before 3PM will be despatched that day)
Our sales team will offer advice on foam products call 01952 581267
Hope that helps Thumbs Up
Post #203811 21st Jan 2013 10:44am
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
Great job you've done on that Matt Thumbs Up
Ive just finished mine (if it is ever really finished), and if it helps, found 12mm flat closed cell foam (I used foil faced foam in the hot areas) fits nicely under the rubber transmission tunnel mat and inside the doors - any thicker and it gets hard to form around the curves.
Post #203813 21st Jan 2013 10:53am
mk1collector
Go Beyond wrote:
Hi Ray,
Excellent Thumbs Up thanks.
Keep up the good work, yours is looking mint!!
Ray
Post #203894 21st Jan 2013 4:35pm
Thanks guys Cool
Post #203896 21st Jan 2013 4:39pm
What are you currently working on on the 130 now Matt? Thumbs Up $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #203901 21st Jan 2013 4:47pm
Hi Steve,
I've nearly finished the rear seat box, cut three holes in it to set two amps in and a plastic storage box and then covered the whole lot in Dynamat and then carpet - Pics to follow ....
Post #203906 21st Jan 2013 4:51pm
Go Beyond wrote:
Pics to follow ....
Look forward to it! With your tailoring skills I don't doubt it'll be a top notch job. Thumbs Up $W33T $0U7H3RN $UG4R
Post #203940 21st Jan 2013 5:40pm
Thank you Bow down
Post #203960 21st Jan 2013 6:03pm
BjornAgain
South Africa 1999 Defender 90 Td5 CSW Chawton White
Go Beyond wrote:
Sound insulation is progressing ...
Interested to know why you put the egg box style acoustic foam on the roof and the dynamat elsewhere...? Apart from cost why not put the dynamat on the roof as well...?
Post #204318 22nd Jan 2013 1:31pm
Hi BjornAgain,
It wasn't a cost reason.
I wasn't convinced that the Dynamat would stay glued to the ceiling and if it 'fell' off would be heavy on the headlining.
Time will tell if the foam will be just as effective in it's sound deadening properties...
Post #204323 22nd Jan 2013 1:38pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
Go Beyond wrote:
Hi BjornAgain,
i thought dynamat glued/sticks really well?
your 130 is coming on nicely, like it.
Post #204334 22nd Jan 2013 1:50pm
Thanks Chadjizz Thumbs Up
Yes, actually now I've used it on the floor it does stick fine.
I don't think I'll be able to tell the difference between that and the foam on the ceiling acoustically though.
Post #204339 22nd Jan 2013 1:56pm
chadjizz
anything is going to be an imporvment any way. i need to kit my 130 out with some. i have taken the rear seats and box out and its even more load now!
Post #204341 22nd Jan 2013 2:06pm
Mr. Green
My rear seat box has a few holes in now ...
Post #204343 22nd Jan 2013 2:13pm
