Home > Puma (Tdci) > REDEX |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
Placebo effect mate
15th Jan 2013 3:11pm |
Probably agree with you there ! We often see what we want to! An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
15th Jan 2013 4:21pm |
sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261 |
mine always seems to go beter when i wash and hoover it
15th Jan 2013 6:42pm |
Mine never goes any better if I clean it................so I don't bother
15th Jan 2013 6:46pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
sc70
you're right however I generally find an increase in performance is only noticable after the second coat of polish. |
15th Jan 2013 7:42pm |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
I put some ( a load ) in an old Honda Civic ! Got chased by the Cops because it resembled an Red Arrows display aircraft. Evan after it had been burned off I always got honked at and lights flashed at me from traffic lights. In the end I would only take it out a night! Her indoors refused to drive it.
16th Jan 2013 1:31am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8027 |
is that not just because it was a civic? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
16th Jan 2013 11:10am |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 |
Use Two Stroke Oil!
Quieter smoother diesel engines. Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
16th Jan 2013 12:39pm |
I put some Redex in my Hillman Husky many years ago, cap full down each spark plug hole and a drop in the carb, just like my old man said When I turned the key and she fired there was a bit of a bang When the smoke cleared I found that I needed a new exhaust, it'd blown the whole lot off completely. The one thing about Imp exhaust systems was that the tail pipe went into the silencer box at one end and the pipe in, bolted straight onto the exhaust manifold.
16th Jan 2013 1:26pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
If you put any sort of liquid in through the plugholes, you should spin the surplus out on the starter before replacing the plugs. |
16th Jan 2013 1:35pm |
It was a long time ago and I was following the advice of my old man That was about the last time I ever did
16th Jan 2013 1:43pm |
So he never advised you on the safe use of an axe.....................
16th Jan 2013 1:48pm |
My old man had an interesting way of teaching, his family's business consisted of a couple of butchers shops in Birmingham where he served an apprenticeship then national Service took him off and gave him tastes and skills anew. He must have enjoyed himself as he stayed on in the services for a while. Then he went into farm work and used to work on Packington Estate, where Land Rover used to do a fair bit of testing and press days as it wasn't that far away from Lode Lane. He spent some years driving HGV's and all the time we had horses around which were allways part of our life.
As an only child, he was allways imparting me with different skills he had picked up along the way, I could use a steel to sharpen a knife from an early age, a lot slower than him though, I would spend hours chopping logs for the fire and Rayburn, learning as I went along. He was a true countryman and an excellent shot, except in later years when his eyesight started to fade and he left us stranded one night when he put a full choke through my Volvo 145's radiator one night out rabbit shooting! He would show you once and then leave you to it, you either carried on doing it his way or found a way to suit you, he didn't mind as long as the task you were doing got done as fast or faster than he did it. He would have been the first to admit that there is no one way to do a job, it was the end result that mattered. |
16th Jan 2013 3:01pm |
Back to redex....
Would double doses of redex each tank full do any harm or benefit? I'm thinking this would be cheaper and perhaps as beneficial as diesel ultimate? |
30th Jan 2015 8:53pm |
