![]() | Home > Maintenance & Modifications > Fuel pump wiring for cutoff |
I'm fitting a tracker with a relay to cutoff the fuel. Please can someone tell me if/where the fuel pump wiring runs in the Puma 2.4 engine compartment and the closest point to get at it through the bulkhead?
Perhaps PM me as it's a sensitive matter? I'll post again if/when I get an answer. Loads of thanks for any help y'all can give... and apologies if it's a bloody stupid question ![]() Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Cutting off fuel as security is widely discussed on the forum (and completely obvious as a protection) - however, how to do it is not for public broadcast, hence my request for PMs
![]() But shout it at them in German because life is also terrifying and confusing... |
Sorry, but I wouldn't even announce whether I'd got an aftermarket system on mine.
............or not. ![]() |
I realise you've a valid point. I guess I feel a bit too safe here in Germany - I really want the security for when I visit the UK
ZeDefender, good question and i'd like to know with PMs ... something to back up the missiles and 7mm
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
All I am going to add to this post is be very careful in how and what you tie into the Pumas wiring, the pump bit you are on about is controlled directly by the EMS ECU,
![]() This fuel hydraulic lock option from X Eng is the next security project for my Puma (I have identified two good places that are out of sight but allow key access)and may be worth considering for yours Matt instead of cutting into the engine harness. Just a thought.. ![]() http://www.x-eng.co.uk/X-Defend.asp |
Thanks Brian - you've also made me twice about giving control of my fuel pump to a Chinese tracker box whilst doing 140 km/h down the Autobahn
![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
