Home > Puma (Tdci) > Fuel light
doberman
United Kingdom 2012 Defender 110 Puma 2.2 USW Galway Green
Fuel light
Hi can anyone let me know how many miles within a little there is left when the fuel light comes on ?
Cheers (2012 110 utility )
Post #198813 3rd Jan 2013 11:46pm
Egghead
Not sure about mileage but my fuel light comes on when I am near enough an eighth of a tank dry (halfway between the 'official' empty line and the quarter tank line on my guage, which is way too early in my mind so I don't sweat about filling up until the needle has dropped below the empty line - after that I start looking for fuel. I wouldn't take it too far below though, Defenders are not the most easy to push to a filling station. Embarassed
On a long journey of course, this is irrelevant, just fill up when you can at the cheapest place.
Post #198822 4th Jan 2013 1:04am
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Mines about 40 after it comes on!! Was spluttering as I went into the garage the other day! I put just over 60 ltrs in it too so must of been empty Wink Wink 90 Puma HT
Post #198829 4th Jan 2013 7:45am
MartinK
Yep, same here, around 8 litres I assume...
Manual says:
Quote:
When the fuel remaining in the tank drops to a minimum of 9 litres (2 gallons). If the indicator illuminates, refuel at the first opportunity
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #198830 4th Jan 2013 8:10am
doberman
Thanks guys
Post #199205 5th Jan 2013 5:29pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Best thing to do is fill the tank when the light comes on, then subtract the amount of fuel added from the tank from the capacity, which is 60 litres on a 90.
I say this because I don't really trust the fuel gauge, mine will read half full after 200 miles, but is totally empty after 300 miles.
Post #199236 5th Jan 2013 6:52pm
Toplink
My light comes on after 290-300 miles.I usually try to fill up within 10-15 miles of this event.
3/4 tank@100 miles,1/2 tank@150 miles,1/4 tank@250 miles, 1/8 tank light on@300 miles. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2014 Triumph Tiger800xc
1999 Discovery 2 td5
1982 Ransomes TSR300D.
2002 Yamaha XT600e.
2010 Freelander2 (the wifes)
2008 John Deere X140
Post #199280 5th Jan 2013 9:09pm
leeds
On our 2.2 90 get about 300 miles before light comes on and tank takes 50 litres to fill. That leaves about 10 litres or max 60 miles when light comes on.
That means we will be putting a wing tank in which will extend range to 480-500 miles. Compared to our 110's that range is pretty low! Rolling with laughter
Brendan
Post #199398 6th Jan 2013 2:05pm
pannawonica
Australia
I generally find that I put in about @63 litres full to light on. Laughing
Post #199413 6th Jan 2013 3:15pm
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
I've had engine hiccups twice after about 15-20 miles with the fuel light on. Some coasting into petrol stations was required Very Happy
Post #199416 6th Jan 2013 3:54pm
keith
SAME problem with my 2.2 110 . 3 times limped and sputtered into fuel station . 15 miles for me when light comes on . and from empty to full is exactly 70L . Another example of LR cutting weight and quality off this last defender by making the tank smaller . My TD5 had a 73L tank and got 400mls from full now max miles on 2,2 is 320 .
Post #199690 7th Jan 2013 1:59pm
jst
tank size hasnt changed, still meant to be 75L, i don't think the pickup/sender unit size has changed either. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #199697 7th Jan 2013 2:15pm
JeremyJ
It is as you say the same size, 75L
Post #199700 7th Jan 2013 2:24pm
keith
YEP so they say but 3 times iv proved it wrong as 3 times i have run out and 3 times its took only 70L max i squeesed in was 70.20 L
Post #199786 7th Jan 2013 8:22pm
I'd guess that just means that the fuel pick up isn't reaching the bottom of the tank. Darren
Post #199813 7th Jan 2013 9:18pm
