Home > Technical > Heat protective sleeve
mse
Anyone know where i could buy about 20ft of 10mm heat protective wrap for my dynema winch line? High temperature protection the better?
I used to know a place but I can't find it Big Cry Mike
Post #189392 28th Nov 2012 10:41pm
K9F
http://uk.farnell.com/?CMP=KNC-GUK-FUK-GEN-PFB&mckv=sRTVHN5s7|pcrid|13360955229|kword|farnell|match|e|plid|&utm_expid=61856916-4&utm_referrer=http%3A%2F%2Fwww.google.co.uk%2F
http://uk.rs-online.com/web/?cm_mmc=UK-PPC...tAod_VAAHQ If you go through life with your head in the sand....all people will see is an ar5e!!
Post #189394 28th Nov 2012 10:48pm
leeds
Dyneema/Plasma are UHMWE polyethylene which will have a melting point of about 120C. However the strength of UHMWPE will start dropping off sharply from about 70C.
Now best heat insulation will be given by glass or kevlar type tubular webbing. Give Andy at Ruftraks a ring on 07806-776311 or David at Bowyers (0)1363 82666
There again good old nylon tubular webbing is better then nothing.
Brendan
Post #189398 28th Nov 2012 11:08pm
mse
David Bowyer is as much use as a chocolate teacup in the desert.
120 or even 70 degrees isn't really enough for a braked winch drum, 300 degrees is where I want to protect.
I'm fortunate to know a bit about this, it's more finding the place that sells the stuff in the uk...Canada I'm sorted. Mike
Post #189407 29th Nov 2012 12:15am
mse
This is the sort of stuff I'm trying to find
Resists temps of upto 370 C Mike
Post #189410 29th Nov 2012 12:33am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Post #189433 29th Nov 2012 8:55am
leeds
That looks like the glass fibre sleeving we used to use on heater bands to protect the wiring..
Cobs has given you one lead also try Fothergill Engineering Textiles.
If they want you to buy large quantities it might be worthwhile talking to a good electrical whoesalers and see what they can source.
Brendan
Post #189436 29th Nov 2012 9:04am
mse
cobs wrote:
try here:
http://www.hightemperaturesleeving.co.uk/
That is the one perfect thanks - ill give them a call... Mike
Post #189541 29th Nov 2012 4:33pm
mse
All ordered - protection up to 600C!
thanks Mike
Post #189558 29th Nov 2012 5:39pm
