Home > Technical > Console lighting
Ric
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Console lighting
Hi, I'm a proud new owner of a defender, first outing in the dark I discovered 1 x headlight bulb out, now replaced.
And then I noticed I cannot see the heater controls, (09reg xs)
Should it be illuminated when the lights are on?
If so, does anyone know where / how to locate the bulb or the fuse.
Thanks
Ric its only a car!
Post #184190 11th Nov 2012 10:11pm
It should be illuminated yes. Someone will be along with bulb details shortly. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #184192 11th Nov 2012 10:13pm
Killer90
Site Sponsor
bulbs are behind the dash center mate and also behind the dash cluster Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #184197 11th Nov 2012 10:22pm
Bulb spec from handbook is:
All Interior lamps - W10W - 10 watts
Post #184292 12th Nov 2012 11:53am
Ric
Just a additional note, the clock light does'nt work also! its only a car!
Post #184465 12th Nov 2012 8:46pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
its not a clock....more a calender. Putting Dreams on Drives at JLR Solihull..
Post #184567 13th Nov 2012 9:05am
Andy Jeff
United Kingdom 1999 Defender 90 Td5 CSW Chawton White
When I got my Defender NONE of the dash lights worked! you can get 'em from Halfords, but I got mine mail order from here:
http://www.svetila.com/en/light-bulbs-lamp...l-503.html
http://www.svetila.com/en/light-bulbs-lamp...l-517.html
The whole dash is easy-peasy to remove - just 4 screws - and from there you'll see the bulbs you need!
Make sure you chose the right ones!
...and no, I couldn't believe how cheap they were either!
Of course, you can always get an LED replacement kit and go for cool blue or something like that, I was sorely tempted!
http://www.repairmylandrover.co.uk/landrov...ng-upgrade
Andy.
Post #184596 13th Nov 2012 10:22am
On the dash centre where the fan 1 2 3 speed / power control is. Is there a bulb directly behind there? My dash is illuminated fine but this one area appears to be very dark indeed. Just wondering if a bulb is gone there. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #185024 14th Nov 2012 5:03pm
BigWheels
Is there a way to turn the console lighting off, when parked & locked but with the parking lights on?
My manual, page 31 indicates switch setting 2 makes it unavoidable to leave the console lit. Waste of battery & bulbs. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #185136 14th Nov 2012 9:12pm
Just for extra info for anyone interested. The bulbs for behind the centre dash are 1.2w capless bulbs. I just bought a couple from Shukers for peanuts. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #189677 29th Nov 2012 9:41pm
