Home > Technical > What's it called? Battery post fixing bolt? |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
I had the same problem when fitting the winch on my 110.
I got round it by getting the correct size bolt and then grinding the head down to form the 'T' using a bench grinder. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
28th Oct 2012 8:16pm |
Odin Member Since: 29 Apr 2011 Location: Aberdeenshire Posts: 237 |
That's a good idea. What's that type of head called? Not even wiki can help!
28th Oct 2012 8:34pm |
If memory serves me it is a T head bolt, normally used for fixing aluminum extrusions.
http://www.acsstainless.co.uk/content/view/17/38/ Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
28th Oct 2012 9:04pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Alternative is a battery clamp with a 8 mm stud. It is possible to fit up to 4 35 mm2 cables onto the stud terminal.
Brendan |
28th Oct 2012 9:10pm |
Cheers Brendan, I got that gear from Dave Bowyers however the new 110 has a nicely made up cable connection that's all protected - don't want to risk cutting back the rubber to remove the existing clamp when this t-head bolt may do the job. |
28th Oct 2012 11:12pm |
