Home > Technical > What's it called? Battery post fixing bolt?
Odin
Scotland 2012 Defender 110 Puma 2.2 USW Santorini Black
I'm trying to earth a winch cable via the battery earth but the 6mm bolt with the 't' end upon which the tapered nut screws to tighten the battery clamp is too short. Only 2mm protudes above the top of the fixing nut. I'm after a longer one so I have enough thread to screw the other cable on. Hope that makes sense!
But, what the hell is that type of bolt called?
Post #179836 28th Oct 2012 7:38pm
bob neville
I had the same problem when fitting the winch on my 110.
I got round it by getting the correct size bolt and then grinding the head down to form the 'T' using a bench grinder.
2013 Defender 90 CSW - sold
Post #179852 28th Oct 2012 8:16pm
Odin
That's a good idea. What's that type of head called? Not even wiki can help!
Post #179861 28th Oct 2012 8:34pm
bob neville
If memory serves me it is a T head bolt, normally used for fixing aluminum extrusions.
http://www.acsstainless.co.uk/content/view/17/38/
Post #179874 28th Oct 2012 9:04pm
leeds
Alternative is a battery clamp with a 8 mm stud. It is possible to fit up to 4 35 mm2 cables onto the stud terminal.
Brendan
Post #179877 28th Oct 2012 9:10pm
Odin
Brendan
Cheers Brendan,
I got that gear from Dave Bowyers however the new 110 has a nicely made up cable connection that's all protected - don't want to risk cutting back the rubber to remove the existing clamp when this t-head bolt may do the job.
Post #179945 28th Oct 2012 11:12pm
