Started putting the 90 back together, after it's return from the paint shop, between the monsoons and thunderstorms.
About 80% done and then called it a day when the lightning hit a tree in the field behind us ![]() Horses were well spooked (so was I !), came into the house and we only had about 30% power as the wonderful electrical distribution system in Somerset kicked the bucket again ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
Hi to everyone,
Drove to Leamington Spa to pick up a roof rack found on eBay. First long trip in the Puma and loved every minute. ![]() Safe driving Nobby _______________________________ Puma Defender 90 |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5889 ![]() ![]() ![]() |
Spent the day on the chassis of the 110 giving it a good paint and good seeing to.
After a few hours it now looks a lot better, just the section from the front outrigger to the front of the chassis next. I did have a "Why did I poke that bit of rust moment" In this case, its the bit where the chassis meets the rear x-member. I decided to remove a clump of rust....but this remove section and left a hole ![]() Regards John M0VAZ Econet Station 48 no clock |
vulcanfreak Member Since: 05 Sep 2010 Location: suffolk Posts: 77 ![]() ![]() |
Slept in the back of my 90 CSW
Took the 110 out for it's maiden voyage with all the modifications complete, all good, no leaks, everything working as expected. Met up with BigRuss and MrsBigRuss for a pint in the forest, then took the long road home.
The D2 duallys work great as DRLs too. |
sweatysock Member Since: 17 Jul 2011 Location: Warwickshire Posts: 283 ![]() ![]() ![]() |
went on a quick run out before I go on my jollies after fitting some checker plate looking matting in the rear tub Sweatysock
------------- 110 CSW TDCI (Puma) 2007 |
Got stuck in crap loads of traffic on the M3 and M27 on my way to the pub to meet Bpman.
Then had a drive round the forest and headed back home. Russell 2011MY 110 XS USW Black |
Well I finished fitting the noise killer to the 90's bonnet it's now so good the Puma is in need of the same treatment. Always unsure how good it was now I can say it is very good.
![]() Puma Defender 90 |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Nobby - did you de-grease the underside of the bonnet? and did it stick quite easily? BM52
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
the noise killer stuff is very good quality aint it, for some reason i couldnt get it to stick to my bonnet
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20626 ![]() ![]() |
Why stick it? Fix it
![]() β½οΈπ’οΈβοΈπ§°πͺ |
With the noise killer stuff what is the outcome of fitting it in the end? Sounds a silly question but I assume it depends where it is fitted. With the Puma I quite like actually hearing the engine well but what I don't like is when you open a window just for some air the wind noise is far far worse and then the engine noise and the wind noise combined is a bit much especially if you are trying to listen to some music
Hi BM52, I used an engine degreaser, let it do it's magic for 10 mins and hosed it off. Once it was dry the bonnet was lovely and clean.
Killer90, it seems to have stuck and held everywhere it was supposed to, still I haven't lifted the bonnet this morning? You can see it for yourself soon anyway? ![]() Custom90steve, it's on a Land Rover 90 with 200tdi engine and needed it, fitted to the interior cab, engine bonnet and I fitted an engine blanket. Fitted new carpets and to be honest it has made a lot of difference, so much that I'll fit a blanket to the Puma. However I do like the sound the Puma makes as well. Most likely wait until I've had it away to Alive for their magic or not! _______________________________ Puma Defender 90 |
