Home > Puma (Tdci) > tubular side steps - heads up
Page 2 of 2 <12
bob neville
LR (not the dealer) were saying they would not replace my rusty standard steps last year so i purchased a set of F & I ones to do the swap myself. LR did replace the steps so I just replaced the new standard ones with the F & I and now another forum member has a brand new set of genuine LR side steps Thumbs Up
2013 Defender 90 CSW - sold
Post #152537 28th Jun 2012 7:48pm
nicholas2012
Scotland 2010 Defender 90 Puma 2.4 HT Tamar Blue
i'm back again not orderd them yet can anybody tell me 100% if they will fit my 90 or not? Confused
As really dont want to end up with steps that dont fit as think i'd struggle for a refund thanks
Post #152679 29th Jun 2012 9:43am
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Just out of interest, does anyone know if you can take the side steps apart? If you were to drill the Rivets for example? my Chequer plate is looking tired, and I think it would be more subtle if the Chequer was powdercoated black?
Alex 110 Tdci Double Cab
Post #152681 29th Jun 2012 10:02am
Yes you can, as I've done exactly that. I've had the main tubes galvanised and then both them and the chequerplate inserts powder coated. I've yet to reassemble them though. I'm not sure whether to use large rivets or to fit rivnuts in the tubes and bolt them on.
 Darren
Post #152700 29th Jun 2012 11:10am
ay4alex
Awesome, thanks LRA
What's the story with the rubber edging strip? can you just pull it off and then re use it when you put it back together?
Cheers, Alex 110 Tdci Double Cab
Post #152705 29th Jun 2012 11:27am
The rubber bit is actually a shaped pad that's sandwiched between the chequerplate and tube rather than an edging strip. Yes, that can be cleaned up and re-used. Darren
Post #152706 29th Jun 2012 11:35am
K9F
Rivnuts must be the way forward in my opinion. For ease of any future disassembly and the fact fastener heads will be a lot more aesthetically pleasing than rivets and you get a choice.
Thumbs Up
Nice job by the way!!!! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #152708 29th Jun 2012 11:49am
Yeah, that was kind of my thinking. I haven't looked at it yet but my only concern is whether I can fit rivnuts of an appropriate size in the existing holes. What I don't particularly want to do is have to start drilling them out now that it's all nicely coated. Darren
Post #152714 29th Jun 2012 12:06pm
Porny
Site Sponsor
You really want to use M6 riv nuts, so you will have to drill the hole out to 9mm (well, about 8.Cool. You then then fit coated or stainless steel riv nuts - and use a M6 stainless button head bolt with a stainless steel washer.
I have just done Tim's (from mobilecentre) so if he is reading this, he might be kind enough to post as picture of the finished article. Wink
Ian
Post #152855 30th Jun 2012 11:07am
Page 2 of 2 <12
