Home > Maintenance & Modifications > lamp guards and rivnuts Aaaarrgh ! |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1763 |
Front light guards always look better on aircon models. They seem to take your eye away from the extended snout.
24th Mar 2012 4:36pm |
Coincidence! I'm fitting rivnuts for my lower lamp guard brackets tomorrow (stupid fiddly tiny bolts at the mo).
Even though I have a "proper" rivnut tool and use it loads (I do lots of fabrication with my lads), I still forgot to change to the right compression collar the other day and realised too late when the holes didn't line up If you're not happy, why not just drill them out and ask a local garage to fit them? Only take a couple of minutes... Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
24th Mar 2012 10:24pm |
if I had those style lights, I would probably go for the perspex covers, however if you are going to change the headlight units, the grills are a great idea because you could use security nuts to ensure the grills are not removed before the 8700's get pinched
25th Mar 2012 6:00am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Do they flip up, how do you get underneath? If you do take them off again it might be an idea to paint them with POR-15 uv type as they do like a bit of rust Sealant will slow down corrosion around the holes
She's looking very nice Rossy |
25th Mar 2012 7:25am |
stainless versions might work better ? |
25th Mar 2012 7:30am |
Can you get them Steve? The trouble with most of these parts from Paddocks, Bearmach, LR etc is that they don't prime/treat the metal first properly or at all so the rust within a couple of years. They thin powder coating or plastic coating will last long enough before the rust shows. Not to bad on light grills just buy some more but on the roof-racks etc that's a lot of money to go rusty on you I know people stopped selling the Bearmach racks because of the complaints.
25th Mar 2012 7:38am |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
They hinge at the bottom so you have to undo the top nuts to, say, change a bulb. But for cleaning purposes theres so much clearance between the grilles and the lights that you can easily get between them |
25th Mar 2012 8:02am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
Persplex covers are good. They provide better protection to gravel rash then the grille type light guards.
If using beam deflectors with perplex guards then after quite a long period of sustained head light use then the adhesive will slowly turn brown. We do know that the perplex covers have saved head light at least on one occasion due to to star shaped crack in it. Going into extremely sandy conditions then the clarity of the perplex is diminished due to the sand. On our red 110 we have a perplex rear door window, be there 4 years Clarity not brilliant but not important as I reverse on mirrors Pros and cons! Brendan |
25th Mar 2012 8:16am |
I've already replaced a busted headlight but they are only about £15 from Paddocks and apart from all the screws that have to be undone they are easy to change. Standard does me but with brighter bulbs. I get these '90% brighter' ones from Halfords when they are BOGOF
The chances of a stone hitting the guard and not the light are quite slim I know but they just liven up the plain non XS black grille. I was going to get a KBX or a Brunel grille but for £50 and 2 hours of foul language/fitting they look like they were always meant to be there ! (I think) |
25th Mar 2012 8:40am |
Done mine - 15 minute job
Ally rivnuts, steel guards and stainless screws - a delightful combination, ripe for trimetallic corrosion - hopefully the Duralac will help. Bit rusty around the holes but it'll never be a serious problem - Hammerite once a year should take care of that Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
25th Mar 2012 9:21am |
cor4 would be a good place to start looking ... |
25th Mar 2012 10:46am |
Yeah yeah yeah rub it in why don't you There's always someone who can do a job that would take me all day in 10 minutes ! But the scary thing is standing in front of your pride & joy with a drill thinking 'I'm about to knock eight holes in you and after that there's no way back' |
25th Mar 2012 11:46am |
Well, I've passed beyond the point of sanity after drilling 100+ holes for the window grilles, chequerplate (corners, sidesteps, wings and bonnet) and parking sensor I've tried to reduce corrosion (according to "the book of Zag") as far as possible but it's going to rust eventually anyway, so what the hell Good luck with yours - I'm sure it will be neater than mine Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... Last edited by ZeDefender on 25th Mar 2012 12:20pm. Edited 1 time in total |
25th Mar 2012 12:11pm |
There's a company on eBay that sell GALVANISED LIGHT GUARDS. Ripe for painting or powder coating. Darren
25th Mar 2012 12:20pm |
