Home > Maintenance & Modifications > Sealing a rivet? |
For reasons too painful to describe (and embarrassing) I need to repair a small hole in the rear door. The simplest solution is to put a rivet through (hardly noticeable on a Defender). As the door is steel, I'll use Duralac anti corrosion on the rivet but is there any way to absolutely stop water from getting under the rivet head? I have creeping crack sealant but is there another "trick" to this kind of thing?
Feeling sheepish Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
22nd Mar 2012 7:12pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10382 |
A rivet
Oh, or a sticker |
22nd Mar 2012 7:14pm |
Oh yeah, you really should amuse us with your story
22nd Mar 2012 7:15pm |
Okay
Well, I was drilling holes through the inside skin to fit a window grill in the beautiful sunshine when I suddenly remembered (too late): a) there is an outside skin b) it's not very far away from the inside one c) it's very thin d) big drills are heavy and carry considerable momentum... It's the kind of mistake one only makes once but still needs urgent repair, since LR (in their infinite wisdom) make the door out of steel I have laquered rivets in the right colour. Advice please (and preferably not the "grow a brain" type)? Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
22nd Mar 2012 7:31pm |
Nice lad!
From the inside get a load of sealant squirted around the rivet, should do the trick |
22nd Mar 2012 7:35pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20375 |
Luckily it was only a door and not body. Accidents can happen Any pics of before and after?
22nd Mar 2012 7:50pm |
Will have to take the grille off again for that then
"After" = 3mm hole from outside, temporarily blocked with butyl (please don't make me show this...) God, I feel stupid Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
22nd Mar 2012 7:56pm |
Could have been worse 10mm or more or something... Dunno what you'd be able to do then.
22nd Mar 2012 8:00pm |
Some kind of warning light
"Warning - don't drill here, you idiot" Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
22nd Mar 2012 8:07pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1782 |
A dab of Sikaflex under the rivet head before setting it and use a sealed 'Advel' type rivet - not just an ordinary pop rivet.
Keith |
22nd Mar 2012 8:12pm |
Cheers Just checked out "Advel" - are we talking insanely expensive riveting guns? Never thought of a seal though (doh) - surely I could make one from butyl sheet for a standard large flange rivet ? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
22nd Mar 2012 9:26pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Drill a few more and go for the Italian Job heist LR look
I think that Series is still around somewhere and a replica has also been done but not very accurate! Sorry changing the subject......You plonker Matt |
22nd Mar 2012 9:59pm |
To shamelessly abuse a quote: "with great mods comes great responsibility"
The other one is: "please mod responsibly" The alcohol reference may be slightly relevant Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
22nd Mar 2012 10:18pm |
Well we've all done it. I remember thumping a cold chisel through a very expensive lorry rad
Once your vehicle has been christened the inevitable following marks don't hurt so much. About a month after I got mine I put a 5" scratch down my rear quarter panel from a staple sticking out of a box - didn't bother me much at all funnily enough, you have to look hard to see it. What I am annoyed about are scratches on the bonnet which are quite visible caused by my me pulling hose form a garage pressure washer over the bonnet - just a stupid thing to do but no point in fretting over it, it's getting it's lives character marks as I am using it for work and when we go camping with the kids well say no more. It's to be used first and foremost I don't mind scratching it myself but god help anyone else that does - my wife's terrified to go near it |
23rd Mar 2012 7:38am |
