![]() | Home > Puma (Tdci) > Normal clutch issues, what do I say? |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
Bottom line is if it's juddering with poor selection they need to sort it, don't let them fob you off
Def-00 Member Since: 11 May 2011 Location: Sharjah Posts: 236 ![]() ![]() ![]() |
Check on the forum for understanding dealers that are more helpful from ppls experience and see if they're close by to you. Secondly I'd keep a record of the complaint you gave them. As when they issue the job card they have to write your complaint and date will be on it as well, if you unfortunately don't get it sorted within warranty period you could stilll battle that you put in a complaint and it hasn't been sorted
defender4 Member Since: 22 Jun 2011 Location: South East London Posts: 411 ![]() ![]() ![]() |
Sounds just like the problem on the older models which the dealers know about and have a kit to sort out. Don't take 'no' for an answer and threaten to go over their heads if they prevaricate.
