Home > Puma (Tdci) > Speedo or lack of it! |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 |
My speedo has stopped working? Is there a fuse or somethin that might have broke? Seem to happen after I washed it!?? 90 Puma HT
26th Jan 2012 7:58pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 559 |
Hi jammer
I dont know about if theres a fuse just for the speedo i would guess its for the complete instrument cluster, I had this on a 07 plate 110 puma once and it was the speedo drive on the transfer box that had seized up (not the electric transducer) it might be this worth a try if all else fails Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
26th Jan 2012 8:16pm |
Anyone know where it's too? And I'll check that first 90 Puma HT
26th Jan 2012 8:28pm |
When the transducer is off you can use a screwdriver to gently prize the drive out of the transfer box and it was that what was seized on the one I did
27th Jan 2012 1:09am |
interesting... if it's the head unit, it's a garage job as the whole head unit will need to be replaced. the good news is the instrument clusters are about 180, the bad news is LR have to re-sync the head to the rest of the electronics in the vehicle (10AS etc)
you can pick up 2nd hand units from scrappys for 50-70 though and they can be sync'd the same as a new one |
27th Jan 2012 7:27am |
Had a fiddle with my speedo, the bit which is connected to the trans box, must of forgot to put the plug back on as I drove to work today and it still doesn't work and drives like a flat slow piece of !! 90 Puma HT
3rd Feb 2012 10:08pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8045 |
i am lost a bit here, you forgot to refit the plug and now performance is massively down? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
4th Feb 2012 7:06am |
