![]() | Home > Puma (Tdci) > Hand brake drum shoes caked in oil! |
roche1800 Member Since: 07 Apr 2020 Location: derbyshire Posts: 359 ![]() |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1184 ![]() ![]() ![]() |
the oil would be leaking from the seal where the rear shaft comes out. I recall on a series at least there is a sort of catch bracket to leads any leaked oil out through a weep hole at the back of the back plate (front side from a vehicle perspective).
While obviously the seal should not be leaking and might need to be changed, it helps if the oil is effectively led to the outside rather than to soak the brake shoes. It can also be that the vent is blocked and pressure is building up inside the transfer case. |
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 53 ![]() ![]() ![]() |
There was an issue with early Pumas where the rear seal was leaking onto the handbrake. I recall I've seen the Service Bulletin on here. I don't think it was to replace the seal but something really simple and fast. Not sure if it worked though.
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1843 ![]() ![]() ![]() |
There was a seal recall - but also there's a felt washer behind the flange. oil leaks along the splines and is flung up the inside face of the drum onto the shoes - impressive you still had a handbrake with that much lube!
HTH Keith |
Waka56 Member Since: 08 Nov 2023 Location: Hamburg Posts: 168 ![]() ![]() |
I'll follow that closely. My hand brake is pretty much useless if it's not on flat ground.
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 660 ![]() ![]() |
I recall reading somewhere that the felt washers were done away with and the threads were to be given a coat of some sort of sealant...but I still recall the seal kit and new drive flange (which is recommended you replace when doing the oil seal )coming with a felt washer..
My hb drum was well oiled as well and was surprised it still seemed to be doing the job, but i replaced ir with a disc conversion anyway..to me a far more practical solution as a handbrake..👍 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2458 ![]() ![]() ![]() |
just add some RTV to the felt and push it through. Then a bit more of RTV on top followed by the big washer and nut. That´s it. Puma 110" SW
Again..the bit I remember reading and what i did when I replaced the seals and flange..
May not have been located that i used.. ![]() Click image to enlarge |
well remembered Andy, I did the sealer either side of the washer so Ill keep an eye on it!
![]() Keith |
Thanks for all the comments. I have fitted a new seal and new felt washer!
Everything has been cleaned so no oil at all, new brake shoes fitted. I have loosened the 17mm nut but the cover is very tight over the new shoes and will only slide about 50%, do I gently tap it. And transmission fluid changed while the tub is off! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20671 ![]() ![]() |
There was a LR recall for that.
The brake drum shouldn't be a tight fit over the shoes if everything is slackened off unless there is a big wear / corrosion lip on the drum.
I'd double check everything is correctly in position as a dragging handbrake can cause all sorts of seemingly unrelated problems - noises, vibrations, IIRC even gear changes etc. Good luck Keith |
