Home > Puma (Tdci) > Problem between 2000rpm and 3000rmp
rusty81
Belgium 2010 Defender 110 Puma 2.4 HT Alaska White
I have had a problem with my tdci 2.4 for a while now:
When the temperature gauge just comes out of cold and is not yet fully at operating temperature, I have a problem between 2000 rpm and 3000 rpm. The engine then makes a strange noise.
Especially when the car is loaded or has a trailer attached to it.
I also see that the combustion is not good. Occasionally black smoke comes out.
I have already done the following:
Turbo replaced last year
Replace injector seals
Inlet manifold cleaned
Replace glow plugs.
Replace map and MAF sensor.
Can anyone help me with what I can do about this problem? Landrover series3 109 1980-1999
Landrover 110 td 1988- 2010
Landrover defender td51999 -...
Landrover defender tdci 24 2010-...
Post #1054013 6th Dec 2024 10:13pm
Black smoke is a sign of over fuelling, is there any air input restriction at all? TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #1054020 6th Dec 2024 11:07pm
Esben Kold
Denmark 2008 Defender 110 Puma 2.4 SW Galway Green
Or perhaps egr related.
Post #1054026 7th Dec 2024 7:19am
Can you describe the "strange noise"? Is it a whistle, shriek, or farty noise by any chance?
Post #1054033 7th Dec 2024 8:11am
landy andy
Check your turbo, exhaust manifold gaskets would be my suggestion.
Post #1054045 7th Dec 2024 10:28am
MK
Vicious cycle. Overfuelling-clogged turbo vanes Puma 110" SW
Post #1054058 7th Dec 2024 12:43pm
rusty81
It's more like a sputtering.
I replaced the turbo last year with a replacement turbo. There's no play in the turbine. I think it could be the wastegate.
Or the injectors. Landrover series3 109 1980-1999
Post #1054064 7th Dec 2024 1:20pm
Was it a new Turbo assembly including a new Electronic Actuator as well? TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #1054065 7th Dec 2024 1:22pm
rusty81
It was a compleet refurbished one with accurator from autodoc. Landrover series3 109 1980-1999
Post #1054068 7th Dec 2024 1:27pm
Try dripping some light oil on the turbo actuator pivots, and see if that makes any difference at all and if the vanes are free.
Presumably the Turbo model number and all serial numbers match the original? TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #1054071 7th Dec 2024 1:34pm
I'd be concerned if it was the waste gate!
There isn't one on a Puma.
Post #1054079 7th Dec 2024 2:55pm
