![]() | Home > Maintenance & Modifications > Puma 2.2 Re-map question |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20588 ![]() ![]() |
You should go for Alives ATRIC, you can then do it remotely from home.
![]() Gary (the owner) would be able to talk you through it. ![]() Big Brother is Watching. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 ![]() ![]() ![]() |
Have you considered Bell Auto Services ?
Pete Bell is a well established and recommended remap provider and has all the data on here to show how much you gain It can be done remotely and he supplies a OB2 reader to link to your phone to read and clear faults Pop onto. His site for more information ( no link to the company.. just a satisfied customer) Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1325 ![]() ![]() ![]() |
+1 for Bell Auto Services.
Pete's 150 map for my 2012 2.2 Puma made a massive difference to the way it drove. I went for the remote DIY installation which was very easy to do and was money well spent. At the time I think the insures ,LV, only wanted an extra ยฃ20 or so in increased annual premiums. I ran the Defender for a couple of years with no problems whatsoever. I also have no link with the company, just a happy customer. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2109 ![]() ![]() |
Before going for a remap I would replace the intake ducting between the airbox ( contains air filter) and the wing side air intake. This pipework is highly restrictive and can be replaced with a much larger bore hose. This will allow the engine to breath much better and help with the MAP.
Oh yes. I forgot about the pipe and airbox mod!!!
Page 10 of this post explains my airbox surgery!!! https://www.defender2.net/forum/topic25864...;start=135 |
Photo courtesy of Yannis from page 10 in the link above which I have image edited.
Iโm unsure what the yellow part is with the screw installed is, but the part I have surrounded in green is the part that is cut out, this is after the job has been done. The black plastic in the blue area is what would be removed, the photo is from after the job was competed.** ![]() Click image to enlarge Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
AlexCW Member Since: 04 Mar 2020 Location: Staffordshire Posts: 67 ![]() ![]() ![]() |
I used Ian @ IRB Developments. Heโs based in the Midlands but a good service and well worth the money.
Mine is a 2013 with the stage 1 and itโs transformed how it drives. Alex 2013 2.2 TDCi Puma Hard Top https://www.defender2.net/forum/topic72473.html |
Bris28 Member Since: 25 Apr 2024 Location: Bristol Posts: 9 ![]() ![]() |
Thanks all for the thoughts and advice. Really appreciated.
I will look into those options. |
Crash7 Member Since: 21 Feb 2024 Location: South Posts: 36 ![]() ![]() |
^ This After buying my 2.2 90 I was quite frankly horrified at the performance, I am also from down South and most of the turners, Alive, BAS, are way up North. I headed to IRB Developments, Ian was superb, he spent a lot time explaining everything, the map has made a huge difference to the drivability. - Highly recommended and worth the journey. |
