Home > Puma (Tdci) > Constant whirring sound coming from engine 2008 110 2.4 |
dsl1995 Member Since: 10 Feb 2024 Location: London Posts: 4 |
Hey all,
Hope you're all good! Purchased my Puma last May and its generally been great - minus all the general repairs that come with owning a defender. I've had a new turbo, brakes and servo in the last year - but this sound coming from the engine has been constant (i think). It's now at the top of my ever growing list of fixes haha You hear it on idle and when driving. Any ideas on what it could be? Had a full service and repairs in December and it seemed to be fixed after the Turbo was changed and small crack in the exhaust was welded back together. I'm not sure if this is normal - but I can't seem to hear it in other videos. Maybe it's a minor thing that I don't need to worry about. I'm now starting to question if it ever disappeared and I was blindsided by the bill i had to pay haha Video below: https://vimeo.com/931596189?share=copy Thanks in advance |
6th Apr 2024 10:23pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
what custom 90 said, I decided to change my belt as a precaution at 12yrs old and 50k miles approx and found one of the pully bearings about to fail, you may need a special tool to undo the fan from the fan pully BAS do one but others are available. DEFENDER 90 TDCI XS,
7th Apr 2024 8:19am |
Cheers guys - appreciate the advice. Going to have a look in to it this afternoon and figure out if thats the issue. Looks like something i could do myself as well to save a couple bob!
Will update you on how it goes! |
7th Apr 2024 11:14am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
Just beware / careful of the fan and moving parts for obvious reasons. $W33T $0U7H3RN $UG4R
7th Apr 2024 12:21pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2005 |
Re fan removal.
For the 2.4/2.2 Puma’s It’s a normal thread, so anti clockwise to loosen nut. For the 2.4/2.2 Puma’s the spanner is 36mm. I found the draper 37536 single ended open 36mm spanner ideal and about £6 on line. The nut can be very tight so spanner may need a sharp tap with a hammer to loosen the nut. I purchased a tool from Bell Auto Services (BAS) to hold the pulley in place while I used the spanner, even then I had to use half of a trolley jack handle on the breaker bar on the pulley tool and the other half of the trolley jack handle on the spanner to get sufficient torque to loosen the fan nut. BAS tool https://bellautoservices.co.uk/store/defen...y-spanner/ You can make one cheaply yourself, See https://www.defender2.net/forum/post739830.html |
7th Apr 2024 1:07pm |
Hey chaps - I had a little look around today and it looks like the bearings have seen better days. Reckon I should change these to - could they be part of the problem? The belt also does look quite worn. Ive attached the photos below - the sound is definitely coming from there.
Also the cap that goes on the top right bearing seems to be missing too - any ideas on the part number for this? Thanks again! Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
7th Apr 2024 8:35pm |
Try the new belt first, then you can do the bearings after when convenient. $W33T $0U7H3RN $UG4R
8th Apr 2024 10:53pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
I'm not sure what you mean by this, what "cap"? |
9th Apr 2024 7:58am |
Cheers @Custom90 appreciate the help on this!
And sorry I meant top right Blackwolf I’ve attached an image of it Click image to enlarge |
9th Apr 2024 10:13pm |
That’s the air conditioning compressor pulley cover. Part number PRF500030 , circa £20 on line.
See part 4 in the diagram https://www.lrworkshop.com/pt/diagrams/lan...ssor_45003 However your original pictures don’t show an air con compressor fitted ! And your last picture shows a 2.2 engine ! |
10th Apr 2024 1:31am |
take the belt off, check each of the pullies for play, replace those that have play or are noisy when you spin them.
It looks like the car has been stood whilst wet as the pullies are quite rusted, I would definitely change that belt as well. As others have said yours is none air con, there are different belts for air con and non-aircon so be sure to get the correct one. Good luck DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
10th Apr 2024 5:34am |
