![]() | Home > Puma (Tdci) > Wheel bearing advice |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
Assuming by "pair" you mean both sides of the vehicle, not necessary. Replace when worn.
If by "pair" you mean inner and outer in the same hub, then yes, definitely! |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1147 ![]() ![]() ![]() |
You can buy a wheel bearing kit for £16 (britparts) or OEM £40, timken most likely. Since you have a jack, in the time it takes you to drop off and pick up the car you can change the bearings yourself (using YouTube as your guild) and keep £200 in the pocket AND you woudl know what bearings were fitted.
Just sayin.. |
Learningasigo Member Since: 30 Nov 2023 Location: Midlands Posts: 28 ![]() ![]() ![]() |
Yes, sorry I wasn’t very clear. Pair as in fronts and rears. I was sceptical of my own suggestion. It’s just the pain of not having the vehicle as it is my daily driver! Although now knowing what the defender bearing ‘tell’ is wrt the sound it should buy me more time to get it sorted, hopefully by my self next time, |
Thanks TexasRover. I need to build up a bit more tools and confidence before I try this level of repair. Also having a spare car would help….The defender is my daily and the only back up is my wife’s car. If I started the job and couldn't finish for some reason (error, tools or parts) I would be in the dog house for sure! |
