Home > Puma (Tdci) > 14 vs 64 Reg - possible purchase advice needed!
Puma_MOG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Good day All,
I am hoping to be viewing a 14 and 64 reg D90 SW in the coming days and fingers crossed, buying one of them!
As I understand it, the biggest differences between the two are DSC and the alcantara headliner being standard from 64 reg on.
From pics alone, the 14 looks to be a bit tidier and 1/2 the miles of the 64, but both are very low miles to begin with.
Assuming both stack up, are there any pros/cons to consider?
Many thanks,
P
Post #1029355 26th Mar 2024 1:36pm
camelman
Are they both XS spec?
Post #1029357 26th Mar 2024 2:10pm
Puma_MOG
Apologies, yes, both are XS and spec wise almost identical.
The 14 has better alloys whilst the 64 has full carpeting and the mentioned DSC and headliner.
Post #1029362 26th Mar 2024 3:06pm
90 Dreamer
virtual identical spec / cars means you buy on condition and service history IMO.......
unless you simply prefer colour or similar??
Post #1029364 26th Mar 2024 3:14pm
Puma_MOG
Both the same colour as well.
So, I've got to look and the 14 reg is the one I've put an offer on.
I raised a concern that I felt the clutch pedal felt feather light which IIRC from years ago when I hand a Puma 90 2.2, the clutch had more heft to it. I did ask if by chance it's been modified but was assured it's stock. Does this seem odd, what with many putting in kits to lighten the clutch?
Post #1029390 26th Mar 2024 6:10pm
I'd say it's worth paying more to avoid the DSC, but I am probably a cynical Luddite. Laughing
Post #1029391 26th Mar 2024 6:11pm
Puma_MOG
Can someone confirm how the clutch pedal should feel? I mentioned this to the dealer and they stated it's normal for a low mileage example. However, I seem to recall my previous 90, also a Puma 2.2, felt much stiffer.
The pedal was butter soft! Feeling a tad nervous now...
Post #1029438 27th Mar 2024 6:37am
andy63
It sounds to me like there might be a servo fitted on the clutch..
Not hard to check.. Lift the bonnet and have a look for a small servo and you will see the clutch master cylinder is now on the end of a servo unit..
Or it might have the lof assist spring and uprated master that some fit, but your description points to a servo.. When or if you fit that it does feel odd having such a light clutch👍
Edit.. The other give away of a servo been fitted is your coolant header tank is likely on the nearside wing now
Post #1029449 27th Mar 2024 7:43am
lightning
As above
lf the clutch works fine then maybe someone fitted some kind of clutch assist device. The clutch will usually get heavier when at the end of its life, not lighter.
Post #1029450 27th Mar 2024 7:44am
Puma_MOG
Thanks All.
I did look under the bonnet but wasn't looking for anything in particular. I'll ask the dealer again to check and confirm if something was added by the previous owner. He seems to think not hence my concern.
As always, the info and support on this site is fantastic.
Post #1029453 27th Mar 2024 7:49am
