Home > Puma (Tdci) > Allisport Puma 2.4L - Silicone Hose Kit - ASH18-BK |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 515 |
I don't know the 2.4 but did a 2.2with silicone hoses, and it was a tedious job making sure I replaced the hoses correctly..
I'd say the hose you have highlighted is one off one side of the egr cooler...🤔 My kit was a 24 hose kit and I found I was one hose short to replace every hose.. The company eventually accepted my point after trying to say the missing hose wasn't part of the kit😩 |
20th Mar 2024 4:54pm |
Gibson Member Since: 20 Mar 2024 Location: Ontario Posts: 4 |
Thank you for the reply. I’ll take another look when I get home from work. Could I ask what kit you used? I’m finding that this kit may not have everything I expected within it. Working through this now with the supplier.
Cheers |
20th Mar 2024 5:16pm |
My kit came from Roose motorsports..
As I said not completely without an issue but they resolved it fairly quickly to be fair.. My suggestion as to your hose location is only an educated guess.. You don't appear to have to have as many hoses as the full kit for a 2.2.. I don't see any oil cooler hoses in the diag and the ancillary hoses on the 2.2 are linked to the various parts by external plsstic Y or T pieces.... Edit... I don't have a fuel cooler |
20th Mar 2024 5:58pm |
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 317 |
I've just changed my EGR valve on a 2.2, and saw this hose.
Click image to enlarge Not sure if this is the same as on a 2.4, but this hose goes to the bottom of the EGR valve, and I don't see it in your diagram. Hope that helps. |
22nd Mar 2024 5:55pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8029 |
Off the heater valve I believe having just removed one Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
23rd Mar 2024 9:15am |
Thank you both. I’ll have another look.
25th Mar 2024 4:26pm |
Just following up this thread up. Thanks gents, yes, it was the EGR hose. My hose kit was a bit of a mix up with part A and B packages. I was missing a box of hoses but all were shipped eventually. Ultimately even in the end, I was still missing a few hoses heater hoses up by the selector switch which apparently are not included due to the different defender variants out there I was told. Although accommodating, there wasn’t any options available. I reached out the Paul at Roose Motorsports for help. Even though my kit wasn’t from him, Paul and his staff were amazing to deal with and were able to supply me the hoses that weren’t included in my kit.
Thanks for everyone’s help! [/b] |
10th Jul 2024 2:37pm |
