Home > Maintenance & Modifications > rubber interior trim
nicolas0505
France
Hello to all
Here I would like some information to redo the interior of my 90 puma. I don't have much of a budget, I thought about taking a rubber roller and making cuts in it. Who has already done this and what results did it give?
Post #1017735 7th Dec 2023 7:28pm
geobloke
Yes, works a treat. Used Trim-Fix contact adhesive to stick it down. The 3mm roll is much bette than the 2mm but obviously heavier.
Post #1017737 7th Dec 2023 7:56pm
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I've got a chequer plate design roll in my loadspace. It's very hard wearing and is more easily hoovered/brushed/wiped out than carpet. Very easy to cut round obstructions like cargo rail or handles. I'd certainly consider it for other floors, seat boxes etc. It's not so good bent round or into corners, and cutting two edges to meet at a corner isn't hugely satisfactory either.
Post #1017749 7th Dec 2023 9:19pm
MattBee
Not my 110 but the back of my old Navara crew cab was lined in it when I took the rear seats out.
You can get the ‘coin’ type with raised dots rather than chequer plate style. It doesn’t hold on to dirt as much as the grooves in the chequer type so easier to keep clean if that’s an issue.
Post #1017759 8th Dec 2023 6:58am
Screbble
I’ve got this on top of the factory carpet.
Good all round.
Easy enough to clean in the vehicle and you can just lift it out and hose it if you wish.
Carpet underneath looks like new.
Post #1017760 8th Dec 2023 7:06am
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
I did the back floor of my 110 with the coin type shown in your picture, this I found to be very good, but moderately stiff. I used the ribbed type as floor mats in the front as it's more flexible, but holds dirt more. I think it was all 3mm. For the rest of the surface's I used 6mm self adhesive closed cell foam and covered it with self adhesive four way stretch carpet.
Post #1017764 8th Dec 2023 7:37am
landy andy
Just ordered a big sheet 2mX2m of 5bar black rubber to cover the load area in my utility. Gone for 5mm thick as will deaden the panels and noise. Also same price as the 3mm and 4mm
Post #1017777 8th Dec 2023 9:00am
landy andy
I’ve done my previous with the same but can only find pic of the DC
Post #1017778 8th Dec 2023 9:03am
nicolas0505
France
I put the rubber roll in a photo to give you an idea, after that there are several choices of patterns, for example smooth, ribbed, hammered, orange peel effect. the back part should not be too complicated in terms of cutting. I have to do the front at the seats and also at the gearbox tunnel and also do the front floor mats at the feet. I'm looking for photos of the front part made with rubber rollers
Post #1017827 8th Dec 2023 5:04pm
Retroanaconda
I used it in the back of my 90, along with carpet on appropriate surfaces. Ribbed for my pleasure.
Post #1017832 8th Dec 2023 6:20pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
What thickness is your matting Retroanaconda?
Post #1017850 8th Dec 2023 10:00pm
Retroanaconda
3mm for the ribbed stuff on the wheel arches. The smooth mat on the floor is off an old rock crusher conveyor and is about 12mm thick.
Post #1017868 9th Dec 2023 10:04am
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I used Wrights Off Road matting to line the rear of my 110. Works really well and make the truck much quieter.
https://www.defender2.net/forum/topic82261-45.html
Post #1017902 9th Dec 2023 4:56pm
nicolas0505
France
Good morning
To fix the rubber did you use glue or just put it?
Post #1018236 13th Dec 2023 11:43am
steveww
For the floors I just placed it down, it's dense stuff and stays in place. For the vertical surfaces, I used contact adhesive.
Post #1018398 14th Dec 2023 3:59pm
